Find y(x)
Find y(x) - Messages
#1 Posted: 9/26/2022 6:13:07 PM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
Hello everyone, I have such a task here, you need to find y (x) for each value of x in the range from 1.2 to 2.4 with a step of 0.2.
X I managed to display and see the result. However, when writing the formula y(x) and trying to display y(x), it gives an error. help me please
Plus I can't figure out how to write sin^2(x) in order to have a formula...
#2 Posted: 9/26/2022 6:17:37 PM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
#3 Posted: 9/26/2022 6:21:06 PM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
And the result should be displayed as x = {}
#4 Posted: 9/26/2022 6:37:29 PM
churichuro
churichuro
28 likes in 79 posts.
#5 Posted: 9/26/2022 6:57:35 PM
1222 likes in 2150 posts.
Seems to be a very old version of SMath Studio (display of ranges, round matrix brackets). May well be that the vectorize function isn't available yet in that version. You might consider upgrading or you have to use an explicit loop with for or while.
#6 Posted: 9/26/2022 7:16:16 PM
554 likes in 1333 posts.
Let's visualize what Martin has perfectly described.
#7 Posted: 9/27/2022 2:02:16 AM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
Oh, I'm sorry, could you tell me how to make a vector over y(x)?
#8 Posted: 9/27/2022 2:56:56 AM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
Ok, I tried to do it through the "for" loop, but it didn't work out very well for me, can you tell me how to do it?
#9 Posted: 9/27/2022 3:55:50 AM
you can either click Vectorize button at right tool window, or directly write vectorize as it is a function.
You can see the button in picture I have uploaded at post #6.
#10 Posted: 9/27/2022 5:20:48 AM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
by clicking on vectorize I have the followingizobrazhenie_2022-09-27_112045189.png
#11 Posted: 9/27/2022 5:35:46 AM
1417 likes in 2873 posts.
That's the dinamic assistance when you write directly vectorize
Here is the vectorize button as shown by overlord in post #6
As stated by mkraska, it is possible that you are using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x)
#12 Posted: 9/27/2022 6:00:48 AM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
As stated by mkraska, it is possible that you might using an old version of the program that doesn't have that function (in that case you have to use a loop to evaluate the function for each n-th value of x)
ok, I understand, but when I write vectorization, there is no such component, most likely there is simply no plugin or am I mistaken?
#13 Posted: 9/27/2022 6:08:12 AM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
#14 Posted: 9/27/2022 6:24:19 AM
Therefore you are in this case:
You have to update to a new version if you want to take advantage of vectorize, otherwise you have to use a loop from the programming palette (for or while); here you have a couple of ways
loops.sm (7 KiB) downloaded 43 time(s).
BTW vectorize() is available in stable releases since SS 0.98.5935 (April 2016); square brackets in ranges are more recent, since SS 0.98.6593 (January 2018)
#15 Posted: 9/27/2022 8:02:43 AM
983 likes in 6866 posts.
sin²(x) is silent code for purpose, often replied by maple
You have to code it as exemplified.
Maths sin2(x) plot.sm (6 KiB) downloaded 48 time(s).
#16 Posted: 9/27/2022 8:32:39 AM
... Previous Smath document has been removed from Smath Community.
#17 Posted: 9/27/2022 8:36:48 AM
I missed this part, sorry. Simply type this sequence (the highlighted content):
sin( > x > keyboard right arrow > ^ > 2
tricks like those shown by Jean Jiraud above are useful if you want to disply the content in a different way or in other cases beyond a beginner level needs (in other words, there is no need to overcomplicate the things here).
Here you have your example with sin^2(x) and probably the more compact way to make it working in your Smath Studio version.
Parlepanpindipon_sin2(x).sm (5 KiB) downloaded 50 time(s).
#18 Posted: 9/27/2022 10:19:15 AM
Parlepanpindipon
Parlepanpindipon
0 likes in 9 posts.
Thx, very much
#19 Posted: 9/27/2022 12:58:16 PM
... no tricks in there, just productive project at will,
that you didn't download, i.e: not helping yourself !
#20 Posted: 9/27/2022 7:34:52 PM
  • New Posts New Posts
  • No New Posts No New Posts
