CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Messages
#61 Posted: 4/21/2023 3:17:35 PM
1402 likes in 1708 posts.
How can I get properties of mixtures e.g
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]"
ref: http://www.coolprop.org/fluid_properties/Mixtures.html
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
Click to enlarge
Click to enlarge
maple-python-coolprop.sm (6 KiB) downloaded 74 time(s).
maple-python-coolprop.pdf (19 KiB) downloaded 80 time(s).
Click to enlarge
maple-python-coolprop-2.sm (5 KiB) downloaded 65 time(s).
#62 Posted: 4/22/2023 5:00:09 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (19 KiB) downloaded 72 time(s).
Mixing gases.pdf (67 KiB) downloaded 88 time(s).
#63 Posted: 4/22/2023 5:34:44 AM
More simple
Click to enlarge Click to enlarge Click to enlarge
maple-python-coolprop-3.sm (10 KiB) downloaded 75 time(s).
maple-python-coolprop-3.1.sm (10 KiB) downloaded 60 time(s).
maple-python-coolprop-3.2.sm (10 KiB) downloaded 76 time(s).
Alvaro Diaz Falconi 4/22/2023 9:32:00 AM
#64 Posted: 4/27/2023 3:09:34 AM
Now you can write like this
maple-python-coolprop-3.3.sm (9 KiB) downloaded 62 time(s).
#65 Posted: 4/28/2023 7:39:13 AM
Or like this
maple-python-coolprop-3.4.sm (10 KiB) downloaded 72 time(s).
maple-python-coolprop-3.5.sm (10 KiB) downloaded 69 time(s).
#66 Posted: 4/29/2023 3:33:10 PM
Click to enlarge
maple-python-coolprop-3.6.sm (9 KiB) downloaded 82 time(s).
#67 Posted: 4/29/2023 10:07:03 PM
churichuro
churichuro
28 likes in 79 posts.
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
#68 Posted: 5/4/2023 10:29:17 AM
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (9 KiB) downloaded 75 time(s).
maple-python-coolprop-3.8.sm (6 KiB) downloaded 73 time(s).
maple-python-coolprop-3.9.sm (8 KiB) downloaded 83 time(s).
#69 Posted: 7/30/2023 8:12:32 AM
usamakhan
usamakhan
3 likes in 75 posts.
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath?
I have working CoolProp
#70 Posted: 7/30/2023 1:33:42 PM
usamakhan
usamakhan
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
#71 Posted: 7/31/2023 3:45:32 AM
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
#72 Posted: 8/2/2023 7:17:11 PM
usamakhan
usamakhan
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/forum/yaf_postsm82120_Understanding-Redlich-Kwong-equation-of-state.aspx#post82120
#73 Posted: 8/3/2023 3:06:16 AM
uni, thanks a lot
Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script.
#74 Posted: 8/4/2023 3:23:07 PM
usamakhan
usamakhan
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
#75 Posted: 8/8/2023 2:01:18 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Phase diagrams with CoolProps.
Click to enlarge
PhaseDiagram.sm (39 KiB) downloaded 79 time(s).
Davide Carpi 8/8/2023 2:10:00 AM
#76 Posted: 8/9/2023 3:47:50 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
Click to enlarge
PsychrometricChart.sm (125 KiB) downloaded 80 time(s).
#77 Posted: 8/21/2023 5:39:50 PM
usamakhan
usamakhan
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/coolprop/HighLevelAPI.html#imposing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
#78 Posted: 4/16/2024 3:55:20 AM
1222 likes in 2150 posts.
It seems that multiple instances of SMath can't use the plugin at the same time.
How to reproduce:
1. Open SMath and access any Coolprop function
2. Open another SMath instance: You get an error message
  • New Posts New Posts
  • No New Posts No New Posts
