CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Messages
#21 Posted: 10/26/2016 5:07:40 AM
1417 likes in 2873 posts.
Also, no dynamic assistance is available. Though disabling the plugin doesn't help.
Dynamic assistance is enabled in the program's options?
Mike Kaganski 10/26/2016 5:00:00 PM
#22 Posted: 10/26/2016 5:39:09 AM
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
С уважением, Михаил Каганский
Davide Carpi 10/26/2016 6:50:00 AM
#23 Posted: 10/26/2016 8:14:41 AM
983 likes in 6866 posts.
Hello Jean, according with CoolProp documentation "Q" stands for "Mass vapor quality", thus 1 is 1 mol/mol
Thanks Davide for "unitless Q" and the link to CoolProp Wrapper
Davide Carpi 10/26/2016 12:50:00 PM
#24 Posted: 10/26/2016 12:49:17 PM
Here's what I see:
Try now
Mike Kaganski 10/26/2016 5:00:00 PM, Radovan Omorjan 10/26/2016 6:18:00 PM
#25 Posted: 10/26/2016 5:02:49 PM
Mike Kaganski
Mike Kaganski
Thanks, Davide!
It's fixed indeed.
#26 Posted: 1/6/2017 9:24:08 PM
1222 likes in 2150 posts.
A german smath user contacted me and asked me to include the steamtable dll for EFI in the portable distribution. They weren't included in the recent update because this involves some additional config work and I assumed that the coolprop wrapper might be a replacement.
According to the mentioned user, the steamtables are of better accuracy than the coolprop functions. Thus I now updated the portable distribution.
The user also asked for speed of sound and isentropic exponent functions. Is there a way to help him?
#27 Posted: 1/8/2017 12:41:22 PM
"WASP" is freeware for 10 minutes use, unlimited sessions.
"WASP" from "Katmar". all properties are tabulated per T(°C) or P(abs).
#28 Posted: 1/8/2017 3:58:05 PM
As for the speed of sound can be accessed using "A" or "speed_of_sound"
For the isentropic functions I googled "isentropic coolprop" and there is something but it is not my field, maybe Mike can give some hints.
#29 Posted: 5/16/2017 6:31:50 PM
timgow
timgow
0 likes in 27 posts.
Hello
On entering >>CoolProp_Props("D","T",298.15*K,"P",10*bar,"CO2")=<< I receive a message "K not defined;
Are the double quotes correct?
Tim
#30 Posted: 5/16/2017 7:35:12 PM
Hello Tim,
You missed the units character (apostrophe) before K and bar -> 'K, 'bar
CoolProp_Props("D","T",298.15*'K,"P",10*'bar,"CO2")
#31 Posted: 5/17/2017 5:10:17 AM
timgow
timgow
Hello Davide,
Thank you for looking into my issue.
I had indeed overlooked the apostrophe, thank you.
I copy and pasted your coolprops statement into SMath but I don't get an answer, instead a red border around the statement.
I also typed the statement in from fresh and I get the same.
Is the ordinary >> = << used on a coolprops statement? Will the answer appear before units are applied to the result?
What is the most simple test to see coolprops working?
Tim
#32 Posted: 5/17/2017 5:21:36 AM
timgow
timgow
This a screenshot of my coolprops entry, attached.Screenshot from 2017-05-17 09-14-49.png
Tim
p.s. I don't see how to paste the image; the Insert Image command asks for a URL.
#33 Posted: 5/17/2017 6:51:58 AM
What's the error message now?
Simplest way to check if it might works should be:
CoolProp_get_global_param_string("version"
Also, here there are 3 worksheets to run as test
#34 Posted: 12/22/2017 9:39:02 PM
Aleksey
Aleksey
1 likes in 2 posts.
lastError="Error message couldn't be retrieved from CoolProp library (buffer size issue?); the second try returned: "
what's the problem?
#35 Posted: 12/23/2017 5:47:39 AM
which versions of SMath and CoolProp plugin are you using?
#36 Posted: 12/25/2017 2:27:58 AM
what's the problem?
There may be two issues:
1. WASP is awfully involved in Basic construction. I coded it in Mathcad 11
Get the Katmar WASP [very complete] free for 2 min session, unlimited sessions.
2. The published Basic is unitless, the CoolProp is unit based,
that is enough to freaked the codes. The Mathcad version from Valery was OK.
Sorry, can't help more.
#37 Posted: 12/25/2017 11:59:35 PM
Aleksey
Aleksey
1 likes in 2 posts.
Error:
version SMath - 0.98(build 6484)
version CoolProp -
[albumimg]1466[/albumimg]
I'm try on the various Windows platforms (32/64):
good result on
Win10x64Pro, Win7x64Ultim
[albumimg]1465[/albumimg]
don't working on
Win10x86Pro, Win10x86Educ, Win7x86Pro
[albumimg]1468[/albumimg]
Best regards,
Aleksey
Davide Carpi 12/27/2017 12:43:00 PM
#38 Posted: 12/27/2017 3:43:32 AM
This is just a comment.
Assume my firm knows nothing about Smath and you are doing a project for us
and the project requires be tracable and you would use CoolProp-Wrapper.
If you can't prove it is certified, it won't pass QA.
CoolProp-Wrapper would be rejected [as simple as that].
IMHO, from this thread, CoolProp must be doctored regardless of the
Win version and/or Smath version.
#39 Posted: 12/27/2017 12:47:24 PM
don't working on
Thank you, reproduced. Something goes wrong with the wrapped 32 bit library (the coolprop dll returns both the correct result as well as an error code, hence the errors shown).
#40 Posted: 1/16/2018 9:28:09 PM
David Avila Cortes
David Avila Cortes
1 likes in 2 posts.
is it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version")" I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension?
  • New Posts New Posts
  • No New Posts No New Posts
