Stable: SMath Studio 1.0.8253 (06 August 2022)
Stable: SMath Studio 1.0.8253 (06 August 2022) - Messages
#1 Posted: 8/5/2022 9:23:29 PM
2270 likes in 3734 posts.
Changes introduced in current build 1.0.8253
Improvements
  • Doubleclick on the unit placeholder (at right-hand side of the calculation result) opens Insert Unit dialog with suggested dimension now;
  • Go to Definition command opens Insert Unit dialog with unit/dimension details when applicable now;
  • Units dialog improved to display unit definition;
  • Approximately not equal operator implemented.
Corrections
  • Closing of the Worksheet when file saving is required fixed;
  • Observations happens in some cases with Approximately Equal operator when comparing small numbers fixed;
  • Command line functionality restored.
Miscellaneous
  • Window with empty Worksheet is now automatically closed on open a file (no empty documents are generated now);
  • Refactoring.
Download
SMathStudioAndroid.1_0_8253.arm64-v8a.apk (12 MiB) downloaded 2924 time(s).
SMathStudioAndroid.1_0_8253.armeabi-v7a.apk (14 MiB) downloaded 2334 time(s).
SMathStudioAndroid.1_0_8253.x86_64.apk (13 MiB) downloaded 2176 time(s).
SMathStudioAndroid.1_0_8253.x86.apk (13 MiB) downloaded 2110 time(s).
SMathStudioDesktop.1_0_8253.Mono.tar.gz (1 MiB) downloaded 14076 time(s).
SMathStudioDesktop.1_0_8253.Setup.msi (3 MiB) downloaded 56993 time(s).
SMathStudioDesktop.1_0_8253.x86_64.astra-orel.glibc2.24.AppImage (10 MiB) downloaded 2342 time(s).
SMathStudioDesktop.1_0_8253.x86_64.ubuntu-22_04.glibc2.35.AppImage (12 MiB) downloaded 2718 time(s).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
8 users liked this post
Вячеслав Мезенцев 8/5/2022 11:48:00 PM, João Felipe Seráfico Melo 8/6/2022 12:04:00 AM, sergio 8/6/2022 5:42:00 AM, Davide Carpi 8/6/2022 6:06:00 AM, NDTM Amarasekera 8/6/2022 6:51:00 AM, Laurent Fournier 8/6/2022 7:54:00 AM, Mark R Harris 8/10/2022 1:52:00 AM, IVR 9/10/2022 1:14:00 PM
#2 Posted: 8/9/2022 11:26:03 AM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Thank you. I haven't been here much, but always support and appreciate the work that has gone into this project.
So, doing a clean OS install and I checked to confirm the latest version. The portable version of 1.8151 did NOT let me know that there was an update available...
#3 Posted: 8/9/2022 12:46:23 PM
1417 likes in 2873 posts.
The "don't check for updates" checkbox is unchecked?
#4 Posted: 8/9/2022 4:51:30 PM
Ruben Sidranski
Ruben Sidranski
Davide,
That is correct. This is for the portable version. Looks like Andrey posted 4 days ago and I was the first comment ... maybe others didn't get the update pop-up message on their full install as well.
Time to reload my OSesesesese.
#5 Posted: 8/12/2022 4:25:06 AM
kadpeter
kadpeter
0 likes in 10 posts.
Привет Андрей!
Я хотел бы использовать в расчётах момент, но до сих пор не нашёл. Положи пожалуйста в SMath (изгибающий момент, вращающий момент, крутящий момент - единицы 'Nm' и 'kNm').
Я нашёл ещё ошибку в венгерском языке, 'Ellenálás' не правильно, надо писать 'Ellenállás' (по-русски сопротивление).
Kaderász Péter
#6 Posted: 8/12/2022 4:59:16 AM
1222 likes in 2150 posts.
Пока момента в списке единиц нет, можете использовать составленные единицы: 'N*'m.
Мне также неудобно что всегда нужно ручно изменить J на. 'N*'m. Но так и будет при наличии 'Nm т.к. это вряд ли хорошая единица по умольчанию для всяких величин размерности сила на длину. Скорее вчего для большинства имеется в виду работа или энергия.
#7 Posted: 8/12/2022 9:31:11 AM
kadpeter
kadpeter
Привет Мартин!
Я уже несколько лет пишу в первый ряд на невидную область дефиницию момента:
Потом я могу использовать Nm.
Kaderász Péter
#8 Posted: 8/31/2022 2:01:51 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 494 posts.
Hello Andrey, to let you know the below was not addressed in 1.0.8253:
Updating from 1.0.8151 to 1.0.8238 broke background printing of smath document. I used to be able to copy paste the file onto one note page (for collaboration), right click on it and "insert as printout" (see screenshot). This functionality broke down with switch to 1.0.8238. I will stay at 1.0.8151 for now.
Cheers
Sasha
  • New Posts New Posts
  • No New Posts No New Posts
