Stable: SMath Studio 1.0.8253 (06 August 2022) - Messages
Changes introduced in current build 1.0.8253
Improvements
- Doubleclick on the unit placeholder (at right-hand side of the calculation result) opens Insert Unit dialog with suggested dimension now;
- Go to Definition command opens Insert Unit dialog with unit/dimension details when applicable now;
- Units dialog improved to display unit definition;
- Approximately not equal operator implemented.
Corrections
- Closing of the Worksheet when file saving is required fixed;
- Observations happens in some cases with Approximately Equal operator when comparing small numbers fixed;
- Command line functionality restored.
Miscellaneous
- Window with empty Worksheet is now automatically closed on open a file (no empty documents are generated now);
- Refactoring.
Download
SMathStudioAndroid.1_0_8253.arm64-v8a.apk (12 MiB) downloaded 2924 time(s).
SMathStudioAndroid.1_0_8253.armeabi-v7a.apk (14 MiB) downloaded 2334 time(s).
SMathStudioAndroid.1_0_8253.x86_64.apk (13 MiB) downloaded 2176 time(s).
SMathStudioAndroid.1_0_8253.x86.apk (13 MiB) downloaded 2110 time(s).
SMathStudioDesktop.1_0_8253.Mono.tar.gz (1 MiB) downloaded 14076 time(s).
SMathStudioDesktop.1_0_8253.Setup.msi (3 MiB) downloaded 56993 time(s).
SMathStudioDesktop.1_0_8253.x86_64.astra-orel.glibc2.24.AppImage (10 MiB) downloaded 2342 time(s).
SMathStudioDesktop.1_0_8253.x86_64.ubuntu-22_04.glibc2.35.AppImage (12 MiB) downloaded 2718 time(s).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
So, doing a clean OS install and I checked to confirm the latest version. The portable version of 1.8151 did NOT let me know that there was an update available...
WroteThank you. I haven't been here much, but always support and appreciate the work that has gone into this project.
The "don't check for updates" checkbox is unchecked?
WroteThe "don't check for updates" checkbox is unchecked?
Davide,
That is correct. This is for the portable version. Looks like Andrey posted 4 days ago and I was the first comment ... maybe others didn't get the update pop-up message on their full install as well.
Time to reload my OSesesesese.
Я хотел бы использовать в расчётах момент, но до сих пор не нашёл. Положи пожалуйста в SMath (изгибающий момент, вращающий момент, крутящий момент - единицы 'Nm' и 'kNm').
Я нашёл ещё ошибку в венгерском языке, 'Ellenálás' не правильно, надо писать 'Ellenállás' (по-русски сопротивление).
Kaderász Péter
Мне также неудобно что всегда нужно ручно изменить J на. 'N*'m. Но так и будет при наличии 'Nm т.к. это вряд ли хорошая единица по умольчанию для всяких величин размерности сила на длину. Скорее вчего для большинства имеется в виду работа или энергия.
Updating from 1.0.8151 to 1.0.8238 broke background printing of smath document. I used to be able to copy paste the file onto one note page (for collaboration), right click on it and "insert as printout" (see screenshot). This functionality broke down with switch to 1.0.8238. I will stay at 1.0.8151 for now.
Cheers
Sasha
New Posts
No New Posts
