1 Pages (9 items)
Deleting Rows an Columns - Matrice Handling - Messages
#1 Posted: 5/30/2021 10:31:23 PM
Some functions for row and column deletion.
For row and column functions accepts horizontal and vertical vectors, range(2) and range(3), numbers.
No need to convert anything during input, and exceeding and subceeding values not be removed.
delete_rowcol.sm (21 KiB) downloaded 67 time(s). (old method)
delete_rowcol.sm (15 KiB) downloaded 71 time(s). (new and faster method)
sergio 5/31/2021 5:16:00 AM
#3 Posted: 6/1/2021 12:23:20 AM
Alternate program. Very fast on large matrix.
Jean's program very helpful. Thank you Jean
New_Matrix_Delete [col_row].sm (24 KiB) downloaded 71 time(s).
#4 Posted: 6/1/2021 11:30:22 AM
WroteAlternate program. Very fast on large matrix.
I tried your solution and found out it is faster with single row or single column removal. Good job.
And also found out transpose method is way much slower if I use ranges or matrices for input.
That method is not fast enough and not a good method when you use vectors of columns or rows for removal.
So I have combined your solution with mine, a fast and feature-full method is born.
New file is added in first post.
NDTM Amarasekera 6/1/2021 1:29:00 PM
#5 Posted: 6/1/2021 12:52:21 PM
From square/rectangular matrix algo style do all at will.
1. delete cols & rows in any shuffled ways.
2. conserve selected rows deleted of 'j'.
3. conserve selected cols deleted of 'j'.
Hopefully, no red in your SS version !
Thanks, be good ... Jean.
Utilities Matrix Minor [col_row] ADVANCED OTHERWISE Copy.sm (21 KiB) downloaded 63 time(s).
#6 Posted: 6/1/2021 1:28:36 PM
WroteI tried your solution and found out it is faster with single row or single column removal. Good job.
Yes it works fast. It is a smart code with added features.
Thank you.
overlord 6/3/2021 9:45:00 PM
#7 Posted: 6/2/2021 3:34:35 PM
A revised version, to delete multiple non-adjacent columns.
Faster on large matrix than my last example in post #3.
New_Matrix_Delete [col_row]_R2.sm (41 KiB) downloaded 66 time(s).
#8 Posted: 6/2/2021 6:12:03 PM
Hi Amarasekera. Please try this other version, which works for single column values or column ranges.
New_Matrix_Delete [col_row]_R2.sm (38 KiB) downloaded 68 time(s).
1 Pages (9 items)
New Posts
No New Posts
