F8 problem?
F8 problem? - Messages
#1 Posted: 7/24/2010 7:27:08 AM
325 likes in 2052 posts.
Hello Andrey,
The F8 functionality is quite good. Changing the same names in the math regions at once. However, I've noticed that clicking on an emty space in the worksheet and pressin F8 can cause "Unhandled exception ... " error. It migh be due to my computer, of course - but it happened to me avery time.
#2 Posted: 7/25/2010 4:01:49 AM
Stefano Delfiore
Stefano Delfiore
1 likes in 6 posts.
Hello Andrey,
I have the same problem, my os is winxp sp3( italian version) and use portable version 0.89 of Smath Studio
the details of error are:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at SMath.Control.CanvasControl.ParseInsertString(String value)
at SMath.Control.CanvasControl.Insert(String value)
at SMath.Desktop.canv.ActionEscaper(String value)
at SMath.Desktop.canv.canvasControl1_PreviewKeyDown(Object sender, PreviewKeyDownEventArgs e)
at System.Windows.Forms.Control.OnPreviewKeyDown(PreviewKeyDownEventArgs e)
at System.Windows.Forms.Control.PreProcessControlMessageInternal(Control target, Message& msg)
at System.Windows.Forms.Application.ThreadContext.PreTranslateMessage(MSG& msg)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop
Assembly Version: 0.89.3856.7126
Win32 Version: 1.1.15.0
CodeBase: file:///C:/Programmi/smathstudio/SMathStudio_Desktop.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman
Assembly Version: 0.89.3856.7122
Win32 Version: 0.89.3856.7122
CodeBase: file:///C:/Programmi/smathstudio/ioman.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
HTMLFileType
Assembly Version: 1.2.3856.6720
Win32 Version: 1.2.3856.6720
CodeBase: file:///C:/Programmi/smathstudio/plugins/HTMLFileType.dll
canvas
Assembly Version: 0.89.3856.7124
Win32 Version: 0.89.3856.7124
CodeBase: file:///C:/Programmi/smathstudio/canvas.DLL
SpecialFunctions
Assembly Version: 1.2.3856.6823
Win32 Version: 1.2.3856.6823
CodeBase: file:///C:/Programmi/smathstudio/plugins/SpecialFunctions.dll
XMCDFileType
Assembly Version: 1.2.3856.6795
Win32 Version: 1.2.3856.6795
CodeBase: file:///C:/Programmi/smathstudio/plugins/XMCDFileType.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
NuLib
Assembly Version: 1.55.3856.7123
Win32 Version: 1.55.3856.7123
CodeBase: file:///C:/Programmi/smathstudio/NuLib.DLL
SyLib
Assembly Version: 1.22.3856.7123
Win32 Version: 1.22.3856.7123
CodeBase: file:///C:/Programmi/smathstudio/SyLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Stefano
#3 Posted: 7/26/2010 4:33:41 PM
2270 likes in 3734 posts.
Thanks. Unfortunately I can't recreate a problem. Please, send to me any file where I can test the exception to fix it.
Regards.
#4 Posted: 7/26/2010 5:07:03 PM
Hello Andrey,
I tried on few more computers today (install and portable SMath) and again the error. There is no need for any file. Just try to run SMath and first thing you do after that is to press F8, nothing else. Or open, say, an example file and press F8. It will be Ok if you click in any region before that. But if you clik eanywhere on an empty space in the worksheet and press F8 "Unhandled exception..." will ocur.
I hope that you could reproduce this or someone else except me and stefanodel
#5 Posted: 7/26/2010 10:41:02 PM
sttrebo
sttrebo
0 likes in 6 posts.
loaded up 0.88 on my windows vista machine (all the latest service packs). hit F8 and got the update dialog. installed the update (0.89), and ran SMath. hit F8 and got the error below.
mscorlib
Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/SMathStudio_Desktop.exe
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.4205 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/ioman.DLL
HTMLFileType
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/HTMLFileType.dll
canvas
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/canvas.DLL
SpecialFunctions
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/SpecialFunctions.dll
XMCDFileType
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/plugins/XMCDFileType.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
NuLib
CodeBase: file:///C:/Program%20Files/SMath/SMath%20Studio/NuLib.DLL
enabled.
For example:
#6 Posted: 7/28/2010 6:50:13 PM
Thanks, reproduced. Will fix.
Regards.
  • New Posts New Posts
  • No New Posts No New Posts
