1 Pages (10 items)
Table Region Problem - Wrong display of a matrix - Messages
#1 Posted: 8/27/2023 5:58:19 AM
Hello !
I have this display problem when trying to pass
a matrix to a Table.
Table_Region_Problem.sm (11 KiB) downloaded 65 time(s).
#3 Posted: 8/27/2023 3:07:33 PM
Hello !
My post #1 is a simple example to show the Table Region problem.
The actual problem is related to a Slope Stability Analysis example,
where the result consist of the following.
1. Strip width
2. Relevant Min Factor of Safety (Min_FS)
3. Center cordinates (x,y) of slip circle relevant to Min_FS
4. Corresponding Radius of slip circle.
1. Strip width
#4 Posted: 8/28/2023 4:31:21 AM
In the attached sheet I tried to automatically compile a results summary. Note that there is a single entry point for unit specification in the algorithm (no chance for mismatch between displayed unit and unit used to calculate the numerical values.
1-3.sm (137 KiB) downloaded 65 time(s).
![2023-08-28 09_20_14-SMath Solver - [1-3.sm_].png](/en-US/file/DykzXx/2023-08-28-09_20_14-SMath-Solver---_1-3_sm___png)
#5 Posted: 8/28/2023 7:53:00 AM
WroteMy post #1 is a simple example to show the Table Region problem.
At post #3 construct the matrix as independent cols, thus compatible Table.
Next, nest the two pertinent cols to explicit your Engineering c/w header.
#6 Posted: 1/4/2024 9:52:24 PM
When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards,
Leonardo.
Leonardo.
#7 Posted: 1/4/2024 10:04:34 PM
WroteWhen I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards,
Leonardo.
Smath Solver 30405 is OK for my Tables.
#8 Posted: 1/5/2024 1:10:03 AM
Leonardo.
New program versions might require to update code of some plugins. The release time it depends on how many plugins are affected and how many changes are required (also the Release Manager seems still not completely restored).
#9 Posted: 1/5/2024 6:10:22 PM
Plugin released, thanks to Andrey for updating the code.
#10 Posted: 1/8/2024 7:32:17 PM
Thanks for your replies, they were of help.
1 Pages (10 items)
New Posts
No New Posts
