function maximize/minimize in Smath Studio - Help! - Messages
I need help for my graduation work, i need to use maximize function in Smath Studio, but i have no idea how to do it
Is there a plugin for maximize / minimize functions in Smath Studio?
WroteHi, guys
I need help for my graduation work, i need to use maximize function in Smath Studio, but i have no idea how to do it![]()
You can write your own functions.
maximize and minimize are peak points of slope.
Take derivative of equation, solve it.
Check the examples below.
maximize_minimize.sm (16 KiB) downloaded 134 time(s).
maximize_minimize with different solvers.sm (28 KiB) downloaded 118 time(s).
I need a maximization function to find the maximum value of each ingredient.
sbalansir. + organoleptika zefira - f-cii Ketle.xls (21 KiB) downloaded 69 time(s).
the exel file contains the values of each marshmallow component that are used in the task.
sbalansir. + organoleptika zefira - f-cii Ketle.xmcd (250 KiB) downloaded 69 time(s).
The whole problem is that the function K(x) is six-dimensional and there is no idea how to find its derivatives.
I need to do the same in Smath Studio, but there are no Given / Maximize / Minimize functions in Smath,
I don't know how to implement this.
Here is everything that I could implement in Smath from the Mathcad file.
diplomnayaRabota.sm (33 KiB) downloaded 76 time(s).
p.s If something is not clear, ask, I will try to answer.
Sorry for my bad eng
Hi, can you upload a pdf instead the mathcad xmcd file, please?
everything is written in Russian, if you have any questions, I will explain.
Mathcad - sbalansir. + organoleptika zefira - f-cii Ketle.pdf (245 KiB) downloaded 85 time(s).
WroteWroteHi, guys
Unfortunately, this does not work with my function, because it is more complex than yours.
WroteUnfortunately, this does not work with my function, because it is more complex than yours.
Here is the first solution for your graphics. Rest are in the example.
This is an ugly and fast solution compiled in a haste.
I am pretty sure someone in the forum will come with a more classy method.
diplomnayaRabota_rev.sm (40 KiB) downloaded 76 time(s).
WroteWroteWroteUnfortunately, this does not work with my function, because it is more complex than yours.
diplomnayaRabota_rev.sm (40 KiB) downloaded 72 time(s).
Thanks for your feedback, but I need to calculate maximize from the function K(x),
not from y(j, x).
Check this pdf Mathcad file:
Mathcad - sbalansir. + organoleptika zefira - f-cii Ketle.pdf (245 KiB) downloaded 78 time(s).
After the function K (x), the vector x is given as the initial approximation
and after that the Given and Miximize functions are used for the K(x) function.
I need to get vector X in Smath.
p.s sorry for my bad eng![]()
WroteGraphs are doctored and more, but can't sanity more
Cheers ...Jean
diplomnayaRabota.sm (45 KiB) downloaded 78 time(s).
Thanks for your corrections
because it's obtained from these functions: "X: = Maximize (K, x) ?
WroteThanks for your corrections
, but the main question was how to get this vector X without the Given and Maximize functions,
That is a total different solver. Smath don't have it integrated.
Maple software has it as Maximize() and Minimize() but plugin doesn't parse it under linux.
At least I couldn't do it with maple plugin.
Maxima can solve that kind of equations with maximize_lp() and minimize_lp().
You have to load(simplex) before using this two functions.
Maybe maxima plugin could work but I can't try it, need a windows user to try it.
I use maxima under terminal, maxima plugin doesn't work with linux.
Regards.
WroteWrotebut the main question was how to get this vector X without the Given and Maximize functions,
The bloc solver Given ... Find, Minerr, Maximize, Minimize
is Mathsoft proprietary specific to Mathcad. No such equivalent Smath.
Given/Minerr for fitting model function to data set is done otherwise
in Smath via Conjugate Gradient ... same or even better.
If there is another way of doing in Smath, expect Designers to help.
Sorry Collab, can't help directly on that ... Jean.
I tried to do this for a simple function through the "roots" function, and in the end I found the maximum,
finding the maximum for a simple function.sm (12 KiB) downloaded 106 time(s).
but there are no ideas how to do this for K (X), since it depends on 6 arguments of the vector x.
Is it possible to somehow implement the same algorithm in my task?
WroteWroteIs it possible to somehow implement the same algorithm in my task ?
The Ancestor of the savant solve is the TKsolve.
The designers of TKsolve are the Founders of Mathsoft/Mathcad.
No Mathcad gurus succeeded to crack the bloc, probably crypted deep.
It's a pity that this method is not solved.
However, a kind of minimizer can be implemented as shown in the attached, and incidentally, obtain a solution (just a little bit) better than Mathcad's.
diplomnayaRabota_nleqsol.sm (83 KiB) downloaded 137 time(s).
WroteHi. There are no minimizers in SMath, with the probable exception of a library in Maxima that can be read and executed, as Overlod point.
Thank you so much for your work. I appreciate it.
Hi, I didn't really understand how you made such a function for the previous maximize problem,
I wanted to ask you to help me solve a simpler problem on this topic.
Milk shake optimization.sm (17 KiB) downloaded 92 time(s).
pdf Mathcad file:
Mathcad - mag.2020 Aleksandr Baranov Optimizacija molochnogo koktejjlja.pdf (99 KiB) downloaded 107 time(s).
In this program, I need to repeat everything in the same way as in the screenshots of MathCad, i attached them to Smath.
I would be very grateful if you could help me.
If you have any questions, ask, I will answer them.
WroteWroteIn this program, I need to repeat everything in the same way as in the screenshots of MathCad, I attached them to Smath
Horrible screen shot, nothing to see for understanding.
Seemingly, you have a system to solve ... something like Butler.
Solve Given_Find [CO2_6179 Butler].sm (162 KiB) downloaded 77 time(s).
I'll try to make a pdf Mathcad file.
Some formulas simply dont fit into the full sheet and go beyond the boundaries.
WroteWroteSome formulas simply don't fit into the full sheet and go beyond the boundaries.
Your Mathcad document is surely badly dressed.
like it turned out to make pdf
Hi. Point is: how to solve that in SMath? Because SMath haven't maximizer, and what you have near to that is al_nleqsolve, you can read that in this way: How to use a traditional solver for seek a maximum with constraints?
So, you have a function K(x) with x element of R^6, a guess xo and the guess value for the maximum K(xo). First, write Check(x), for restrict x for the constraints. Next, because numerical solvers for roots needs the evaluation of the change in the target value, assume that you are looking for the zero of f(x) = K(x) - (1+p)*Ko, where p is some percent increment over Ko. Why? Because you guess that xo it's a good solution, so, Ko = K(xo) "must" to be a good guess for the maximum. The Maximize ad hoc function it's just the implementation for that: here the trick is use K(Check(x)) instead K(x). You can try to change the p-value for get the best answer that you can.
The Mathcad's screenshots are perfect. Here you have a little difference: the restrictions involving another function Kc(x), but it's very similar, and need to write CheckX for x and CheckKc for Kc(x). The trick for CheckKc(x): No one, but three:
First, return some information to the solver about how the things are going. Instead of return 0 or 1, return 0 for Kc is in the good interval, and +/- normi(x) if not.
Second, include CheckKc(CheckX(x)) as second row in the target function for try to get zeros on both components.
Third, include CheckKc in the exit condition for the main loop.
Milk shake optimization nleqsol.sm (1 MiB) downloaded 107 time(s).
Hope that's helps.
GoldenSectionSearch.sm (21 KiB) downloaded 322 time(s).
GradientDescent.sm (16 KiB) downloaded 273 time(s).
NCGM.sm (19 KiB) downloaded 259 time(s).
LevenbergMarquardt.sm (45 KiB) downloaded 291 time(s).
NewtonMethod.sm (18 KiB) downloaded 320 time(s).
NelderMead.sm (33 KiB) downloaded 265 time(s).
GaussNewton.sm (20 KiB) downloaded 292 time(s).
New Posts
No New Posts
