Beta: SMath Studio 1.0.8206 (20 June 2022)
Beta: SMath Studio 1.0.8206 (20 June 2022) - Messages
#1 Posted: 6/20/2022 8:44:05 AM
2270 likes in 3734 posts.
Changes introduced in current build 1.0.8206
Improvements
  • if(..) function extended to support any number of arguments more or equal to 2;
  • Approximately Equal operator implemented (Options dialog extended with an appropriate setting; button added to the Boolean toolbox);
  • Defined Integral supports units now;
  • Rendering of the text improved in program dialogs;
  • Electron-volt (k, M, G, T) unit added;
  • Sleep function added allows to suspends the current thread for the specified amount of time specified in milliseconds;
  • Proxy settings implemented.
Corrections
  • Numeric calculations with units corrected in cases when final result is equal to zero.
Miscellaneous
  • Startup of Desktop version is made faster in the environments where access to printer is slow;
  • High DPI support improved;
  • Displaying of the previews improved in Insert Function dialog;
  • Offline login logic corrected;
  • Settings dialog refactoring;
  • SMath LLC code certificate issued and included into repository.
Download
SMathStudioDesktop.1_0_8206.Mono.tar.gz (1 MiB) downloaded 2146 time(s).
SMathStudioDesktop.1_0_8206.Setup.msi (3 MiB) downloaded 4454 time(s).
6 users liked this post
Вячеслав Мезенцев 6/20/2022 10:30:00 AM, Martin_B 6/20/2022 1:23:00 PM, churichuro 6/20/2022 5:55:00 PM, sergio 6/20/2022 10:13:00 AM, Davide Carpi 6/20/2022 3:17:00 PM, Denis Nikitin 6/23/2022 5:17:00 AM
#2 Posted: 6/20/2022 8:56:34 AM
Any case of "if" statement is available now.
Approximately equal operator is available now (see Options dialog to set the accuracy):
9 users liked this post
churichuro 6/20/2022 5:55:00 PM, NDTM Amarasekera 6/20/2022 11:13:00 PM, Mark R Harris 6/21/2022 7:29:00 PM, João Felipe Seráfico Melo 6/20/2022 9:46:00 AM, sergio 6/20/2022 10:12:00 AM, Arie 6/20/2022 11:27:00 AM, Alvaro Diaz Falconi 6/20/2022 1:22:00 PM, Martin_B 6/20/2022 1:23:00 PM, Davide Carpi 6/20/2022 3:17:00 PM
#3 Posted: 6/20/2022 4:19:51 PM
Arie
Arie
93 likes in 285 posts.
Hi Andrey,
I see the "Approximately equal" operator accuracy varies from 0 to 15. What does this value actually represent?
#4 Posted: 6/20/2022 6:51:54 PM
Hi! It is an accuracy of the "Approximately equal" operator. F.e. if the accuracy is 0, then pi≈3, if 1, then pi≈3.1, if accuracy is set as 2, then pi≈3.14 etc.
#5 Posted: 6/21/2022 2:40:14 AM
Laurent Fournier
Laurent Fournier
9 likes in 66 posts.
Great to see Smath Studio is continuously improving!
#6 Posted: 6/21/2022 2:56:41 PM
115 likes in 329 posts.
Hi Andrey,
considering that the "accuracy operator" parameter that regulates "approximately equal" is unique, wouldn't it be appropriate that it is defined in percentage terms?
#7 Posted: 6/21/2022 4:30:56 PM
Arie
Arie
It's more than just the decimal place precision.
approximately.sm (4 KiB) downloaded 77 time(s).
#8 Posted: 6/21/2022 5:38:46 PM
Arie
Arie
Hi Andrey,
Regarding that.. I think "precision operator" more appropriately reflects the intended purpose.
#9 Posted: 6/21/2022 6:56:10 PM
554 likes in 1333 posts.
This is a nice new feature.
Would it be possible to modify this value independent to regions?
Adding another submenu to region right-click would be awesome.
As in decimal places, exponential threshold, rounding choosing.
#10 Posted: 6/21/2022 10:18:57 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi. About the new approximately equal operator, another way to introduce it could be introducing a general infix operator, like in Mathcad. This screen capture is from Mathcad 6 running in Windows 3.11:
For work with units you just need to modify the rhs by abs( a-b ) < UnitsOf( a-b )*TOL (or maybe UoM). Notice that also can be a solution for another features requests, like this one about inline division: https://en.smath.com/forum/yaf_postst21614_Inline-division.aspx
About the "Defined Integral supports units now" it is a major improvement, and while there will be many worksheets to update, it is a substantial and very welcome improvement. I do think that some kind of special announcement should be made. Also, if you plan to also modify solve and roots to accept drives, you may want to introduce the two improvements together in a future stable beta release.
Finally, many thanks to you Andrey and to all the developers who collaborate with the plugins for this excellent program.
#11 Posted: 6/21/2022 11:20:49 PM
zackchen
zackchen
0 likes in 11 posts.
Improvements
Corrections
Miscellaneous
Download
how to input else if? I use SMathStudioDesktop.1_0_8206.Mono
#12 Posted: 6/22/2022 3:30:47 AM
1417 likes in 2873 posts.
In the placeholders of the if() function type an "argument separator" symbol (comma or semicolon, usually)
The if without else will improve alot the readability of many scripts, thank you Andrey.
churichuro 6/22/2022 10:55:00 AM, Andrey Ivashov 6/27/2022 4:57:00 PM
#13 Posted: 7/4/2022 11:23:53 AM
Александр
Александр
0 likes in 10 posts.
Перестали вычисляться безразмерные интегралы
#14 Posted: 7/4/2022 4:05:19 PM
Александр
Александр
Thank you. But the problem is not because of eval(). She's somewhere deeper. My f3(x) and f4(x) limits are ainterp() of the table data.
#15 Posted: 7/4/2022 5:22:02 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Yes, I see that there are more than one issue with the double integration, even for some simple cases it is not sowed.
#16 Posted: 7/5/2022 5:38:34 AM
Александр
Александр
You don't provide enough maths for attempting to doctor.
You may get inspired from the double Simpson integrator.
Please, don't hesitate ... Jean
Double Integration Forum.sm (36 KiB) downloaded 69 time(s).
The question is why in the stable version integrals are calculated without problems, but in the new one it gives an error in the same places?
#17 Posted: 7/5/2022 5:45:21 AM
Александр
Александр
... more in there.
Integrate_0 Double Triple.sm (30 KiB) downloaded 71 time(s).
#18 Posted: 7/5/2022 9:35:25 AM
Александр
Александр
The question is why in the stable version integrals are calculated without problems, but in the new one it gives an error in the same places ?
In other words, you declare a bug.
Designers need the document for doctoring.
... doctor since which SS version ?
1.0.8151.26932 OK
1.0.8206.25180 NFG
Yes, I'm reporting a bug. In version 1.0.8151.26932, dimensionless integrals with limits in the form of arbitrary functions are calculated correctly. In version 1.0.8206.25180, such integrals are not evaluated. The error "x/y - undefined" is returned.
#19 Posted: 7/5/2022 10:43:10 AM
Александр
Александр
It may be the XLS import ?
Try NOT import as a stand alone system.
It doesn't matter if there is an import from Excel or not.
Proizvol'noe sechenie_no XLSX.sm (73 KiB) downloaded 74 time(s).
#20 Posted: 7/5/2022 3:35:25 PM
983 likes in 6866 posts.
Confirmed: works fine SS 6179
  • New Posts New Posts
  • No New Posts No New Posts
