Maxima Plugin
Maxima Plugin - Messages
#1 Posted: 9/20/2013 9:30:11 AM
1222 likes in 2150 posts.
The Maxima plugin is an interface between SMath Studio and the free and open source computer algebra program Maxima.
There is an English handbook for the plugin: https://doi.org/10.25933/OPUS4-2949
7 users liked this post
Radovan Omorjan 9/20/2013 10:38:00 AM, Viktor 1/3/2024 4:18:00 AM, Andrey Ivashov 3/22/2019 11:06:00 AM, IVR 9/20/2013 1:52:00 PM, ioan92 9/20/2013 3:54:00 PM, Davide Carpi 9/20/2013 9:38:00 AM, Вячеслав Мезенцев 9/20/2013 9:58:00 AM
#2 Posted: 9/20/2013 9:41:37 AM
1417 likes in 2873 posts.
I'll test this plugin ASAP, seems a huge work
About variable's definition:
store.AppendDefinition("varible_name", Term[] answer, new Term[0]);
(answer is the RHS)
Best regards,
Davide
Martin Kraska 9/20/2013 11:44:00 AM
#3 Posted: 9/20/2013 11:03:39 AM
kilele
kilele
133 likes in 397 posts.
  • Due to registring a path to Maxima during setup, SMath is not really portable any more unless you can use the same Maxima path on different systems
    [/list]
  • Thank you very much, Kay and Martin!!
    You may want to contact the author of the portable version of Maxima at portableapps.com
    http://portableapps.com/node/23391
    Some other resources that may help are :
    Swig to interface C/C++ with C#
    http://en.smath.info/forum/yaf_postsm10783_Cephes-Math-Library.aspx#post10783
    SWIG and Common Lisp
    http://www.swig.org/Doc1.3/Lisp.html
    Simple C++ CAS Maxima API
    http://code.google.com/p/remote-maxima/
    C# code to connect to Maxima
    http://www.math.utexas.edu/pipermail/maxima/2009/016554.html
    #4 Posted: 9/20/2013 2:19:32 PM
    325 likes in 2052 posts.
    Many thanks to Kay and Martin
    I really enjoyed browsing the Martin's Handbook with Maxima examples. I can see there are some problems with localization settings, (point, coma <=versus=> coma, semicolon). I had no problems with the Maxima examples until I changed to point as decimal point, and coma as argument separator - see the picture please.
    [albumimg]295[/albumimg]
    I did not see this in the ToDo list or Known Issues (maybe I am wrong).
    On the other hand, I suppose that something could be done in order to make this "portable" as kilele mentioned. I know there is software which include some Maxima support but there is not need to install Maxima at all.
    Martin Kraska 9/20/2013 3:10:00 PM
    #5 Posted: 9/20/2013 3:08:40 PM
    Maxima-diff() seems to trouble functions from Nonlinear Solvers. I hope this can be fixed, or Davide finds a smart way to adjust to it without rewriting everything. Last resort would be to provide the functions directly based on Maxima. First we should try to fix diff().
    #6 Posted: 9/20/2013 3:28:30 PM
    In principle, the arg and dec sep issue as well as function style was meant to be handled, but to be honest - not tested. Should be possible to fix, as proven by many other plugins. The localization issue is quite top on the agenda.
    @Andrey, is there a generic solution coming up soon or should we cope on our own for the time being?
    As to the portable version. Honestly, I would rather focus on convenient and stable operation rather than on installation issues. If non-portability turns out to be prohibitive for otherwise active users, this, of course, should be handled.
    But be aware that Maxima is as big as 30MB in download and 100MB unpacked.
    We also think of generic unicode support (as extension of the translator function) in order to enable e.g. cyrillic letters in expressions.
    Let us know what the priorities are for you.
    #7 Posted: 9/20/2013 6:16:41 PM
    Plugin updated. Now Maxima should be started whenever required (this formerly failed at least for int())
    EDIT: Update did just hide the problem, but did not solve it.
    #8 Posted: 9/20/2013 6:24:54 PM
    To create a Taylor series in a SMath worksheet one can write:
    [MATH eng]Taylor(f(x),x.0,degree):line(T(z):sum((diff(f(z),z,n)*{(x-z)^n}/{n!}),n,0,degree),T(x.0),2,1)[/MATH]
    Working from the plugin, NonlinearSolvers build the T(z) RHS, call a symbolic calculation and then replace with a C# while all the [MATH eng]z[/MATH] variables with [MATH eng]x.0[/MATH], this is made to leave clean the canvas from internal variables (but maybe there is another way that I don't know or that I've missed)... Maxima probably crashes against the while cycle (but I'm not sure)
    Martin Kraska 9/20/2013 7:14:00 PM
    #9 Posted: 9/21/2013 3:06:21 AM
    BUG/Dangerous feature:
    Currently MaximaLog(), int(), diff(), lim() and sum() do not trigger start of a session!
    Maxima must be started explicitly in order to take over the internal functions int(), diff(), lim() and sum().
    Maxima session start can be triggered by one of
    - any VALID MaximaControl() command (valid command strings are shown in the dynamic assistant)
    - Maxima() with any argument accepted by SMath preprocessing
    - one of the functions Solve(), LinSolve() or Algsys()
    Make sure to re-calculate the document if you started the session by adding such a command into an active document.
    This means that documents can behave differently depending on whether Maxima is running or not.
    This is a bug/dangerous feature which we try to fix ASAP.
    Meanwhile it is safe to stick to the recommendation in "Plugin Maxima.sm": Each document should at least do a cleanup at the beginning. This is to avoid interference between different open files in the same SMath instance and makes sure that Maxima is started. Use optimization> "None" or "symbolic" to see the "done".
    MaximaControl("cleanup" )=done
    #10 Posted: 9/21/2013 6:50:35 AM
    Regarding to the starting/closing Maxima session, I have some experience with Maxima sessions in other software, and in SMath it happened the same. Sometimes, we can close SMath, end up with/without SMath crash and one or more "maxima.exe" processes remained opened (we could see and should close them in the Task manager, to avoid further problems). I do not know when this happened and why, just wanted to point out how to avoid some possible troubles.
    Martin Kraska 9/21/2013 8:13:00 AM
    #11 Posted: 9/21/2013 8:43:06 AM
    kilele
    kilele
    killing a process seems to be a bit tricky, the accepted response on this thread could be useful
    http://stackoverflow.com/questions/17024729/how-to-kill-process-regardless-whether-its-32-or-64-bit
    Martin Kraska 9/21/2013 7:22:00 PM
    #12 Posted: 9/22/2013 6:10:39 PM
    Fixed, plugin updated.
    Radovan Omorjan 9/23/2013 7:00:00 AM
    #13 Posted: 9/22/2013 6:16:20 PM
    Maxima now does not overwrite the functions diff(), lim(), int() and sum(), because of the problems sum() and diff() can cause. Thus, we hope that Maxima now won't interfere with existing sheets as long as you do not ask explicitly by MaximaControl("takeover" ).
    #14 Posted: 9/28/2013 8:00:51 PM
    Plugin updated.
    • pi translation fixed
    • sum() works but yet summation variables must be undefined
    • logging and control improvements
    • translation of scientific number format fixed
    • translation of Maxima lists and lists of lists implemented (translated into matrices)
    • SVN doc updated
    Maxima.sm (34 KiB) downloaded 439 time(s).
    #15 Posted: 10/9/2013 6:46:53 PM
    Plugin updated.
    Now the sum counter is local to the sum (previously, it had to be undefined, thus i could not be used as counter)
    sergio 10/10/2013 3:28:00 AM, Radovan Omorjan 10/10/2013 9:08:00 AM, Davide Carpi 10/10/2013 2:38:00 AM
    #16 Posted: 10/20/2013 12:59:01 PM
    Plugin updated.
    - Expression size limit is now just by user's patience
    - Maxima questions about sign of variables or expressions in integrals are forwarded as error messages.
    - Units are assumed to be positive in integrals and differential equations.
    update3a.sm (21 KiB) downloaded 280 time(s).
    Radovan Omorjan 10/20/2013 3:33:00 PM, sergio 10/20/2013 4:54:00 PM
    #17 Posted: 10/20/2013 1:08:24 PM
    Serious translation problem with unary minus in exponents.
    Currently, we see no easy way to mitigate that. The attached sheet demonstrates some alternative approaches but they all would involve more than just some regular expressions.
    The reason is in the incompatible operator priority between Maxima and SMath, none of both sides can be blamed for that, except that the very low priority of unary minus in SMath is really unusual and is cause of other problems (try displaying -10°C).
    Radovan Omorjan 10/20/2013 3:34:00 PM
    #18 Posted: 10/27/2013 1:57:00 PM
    Plugin updated.
    - Translation problem with unary minus in exponents solved (thanks to Leo Butler, one of the Maxima developers)
    - Dedicated function ODE.2 for solving second order ODEs (wrapper for ode2())
    - Bi-directional translation of greek uppercase letters
    - Unidirectional (SMath to Maxima) translation of relational and boolean operators
    - Improved error message forwarding
    Andrey Ivashov 10/27/2013 3:29:00 PM, Radovan Omorjan 10/27/2013 3:29:00 PM, sergio 10/27/2013 2:46:00 PM
    #19 Posted: 11/9/2013 1:11:01 PM
    Plugin updated.
    - Bidirectional transfer of string constants
    -> more convenient plotting
    -> Maxima string functions can be used
    - Special markup for verbatim Maxima expressions ("$...$" )
    - Special markup for quote character in MaximaLog() output
    - Auxiliary files now reside in the plugin directory
    - Bidirectional handling of different operator priorities in expressions like a^b^c or a^-b*c
    Andrey Ivashov 11/9/2013 4:02:00 PM, Radovan Omorjan 11/10/2013 2:28:00 AM
    #20 Posted: 11/13/2013 5:09:47 PM
    554 likes in 1333 posts.
    I don't know if it is only me but since last updates I can not use this plugin. At home my win7 x64 computer finds it and works as it is supposed. But at work I have a win7 x86 computer (non-english) and it can never find where maxima is. I have manually written "maxima.inf" file and it didn't helped. I have written thr MaximaControl ("init";"C:\\Program Files\") command and waited for 50 minutes and nothing happened.
    • New Posts New Posts
    • No New Posts No New Posts
