How to calculate the max and Min Values For 24.4±0.015? - Messages
I want to find out the maximum without having to write a code.
How is it possible?
http://smath.info/live/?file=3857
But there would be a Problem:
How can you enter a value of e.g. 25 +0,1/-0,2 or 25 +0/-0,2 ??
Any ideas?
WroteHow can you enter a value of e.g. 25 +0,1/-0,2 or 25 +0/-0,2 ??
It's not difficult, just use the multiple values item (type "sys(" or click on the curly bracket in the "functions" right panel)
[LIVE width=259 height=195]http://smath.info/live/?file=3861[/LIVE]
regards,
w3b5urf3r
WroteThanks w3b5urf3r,
but then I have the same question as in the beginning of this thread: how do I get the min / max-value of this result?
example
(btw how did you enter the preview of the live file in your post?)
For the max() and min() values use the snippet sys2mat() in the attachment
To show the preview click on "Get link..." in the bottom-right corner of Live SMath and copy&paste in your post the 2nd link
best regards,
w3b5urf3r
sys2mat_example.sm (11 KiB) downloaded 92 time(s).
I get an error message "mat()-function is not defined" on every term below the line tc:= sys2mat(tc)
I use Smath 0.95 build 4594 on linux (same also on version 0.94 on linux).
Another question: Does SMath have something like a median-Funktion (= find the value between two given numbers)? Because the usual production process tries to work in the middle of the tolerance field this value could also be interesting to know in a tolerance chain.
Btw, why isn't it possible to transcode a system into a matrix with a build-in function? Or enhance the min/max/lenght/... function to work also with a system and not only with a matrix/vector? Is this not a common problem?
WroteHmmm - this looks like it's my computer (running on the older ubuntu 8.04 (server version)) that have this problem. Update is scheduled, let's see how it changes.
Try this SMath DEB packages. During the installation, missing dependencies will be reported, if any.
WroteAnother question: Does SMath have something like a median-Funktion (= find the value between two given numbers)? Because the usual production process tries to work in the middle of the tolerance field this value could also be interesting to know in a tolerance chain.
You can try with linterp() or building a function like [MATH]med(A;
WroteBtw, why isn't it possible to transcode a system into a matrix with a build-in function? Or enhance the min/max/lenght/... function to work also with a system and not only with a matrix/vector? Is this not a common problem?
I don't know, it's not yet implemented but SMath is in continuous development and something can escape... I'm sure that in a future version there will be some improvements, specially if you report your Feature Requests... f.e. an improvement of max() and min() is requested from several users (max and min), and the support of systems is something that should be included but it's not reported
regards,
w3b5urf3r
Why I am getting different answers?
(http://www.yourfilelink.com/get.php?fid=816752&dv=1)
Thanks,
Basile
WroteHello,
Thanks,
Basile
yourfilelink.com report: "Incorrect linking code. Please try again."
can't you attach the file on your post?
w3b5urf3r
WroteHere should be...
it's the optimization in the definition of [MATH]R[/MATH], [MATH]R,eq[/MATH] and [MATH]R,e[/MATH] (see optimization of coloured equations in the attachment)
regards,
w3b5urf3r
sys.sm (13 KiB) downloaded 66 time(s).
Pay attention how sys() is working. In this simple example, every element from both sys() are combined with each other:
[MATH=eng]sys(1,20,2,1)+sys(50,300,2,1)=sys(51,70,301,320,4,1)[/MATH]
Sometimes it behaves differently, it depends on optimization applied.
Optimization numeric:
[MATH=eng]sys(1,20,2,1)+sys(1,20,2,1)=sys(2,21,21,40,4,1)[/MATH]
Optimization symbolic:
[MATH=eng]sys(1,20,2,1)+sys(1,20,2,1)=2*sys(1,20,2,1)[/MATH]
Actually: [MATH=eng]2*sys(1,20,2,1)=sys(2,40,2,1)[/MATH]
To be honest, because sys() in the calculations can sometimes be quite confusing, my advice is to avoid it in calculations. Actually, I did not figure out yet where the sys() environment is the most useful for using - excluding plots.
But how somebody will know a priori to leave the default or change the optimization?
Thanks,
Basile
I found the reason why your snippets don't work on my machine. Change the decimal symbol to comma and the arguments separator to semicolon and you get the same errors. With decimal symbol "period" and argument separator "comma" everything is fine.
Haven't tested if this is a bug or a feature...
Because Andrey is improving the min/max-function in near future these snippets won't be needed any more (probably/hopefully)
greetings
jabadu
WroteHello w3b5urf3r,
greetings
jabadu
Thank you very much...
seem it's an issue (BUG?) of the built-in functions [MATH]str2num(#)[/MATH] and [MATH]num2str(#)[/MATH] that have different behavior changing interface settings (see the attachments)
(probably the wrong behavior is in [MATH]num2str(#)[/MATH] but I'm not sure)
regards,
w3b5urf3r
num2str_str2num_bug.sm (5 KiB) downloaded 64 time(s).
Regards.
New Posts
No New Posts
