AppImage File Crashes on Linux Mint v22
AppImage File Crashes on Linux Mint v22 - I am using Linux Mint v22 and when I attempt to run the ".AppImage" file, it crashes? - Messages
#1 Posted: 12/4/2024 8:11:39 AM
Keith
Keith
1 likes in 3 posts.
I am using Linux Mint v22 and when I attempt to run the ".AppImage" file, it crashes with the following errors:
Quote
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_generic_class_init(intptr)
at System.Drawing.Graphics.FromHdcInternal (System.IntPtr hdc) [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (System.IntPtr display_handle) [0x0007e] in :0
at System.Windows.Forms.XplatUIX11..ctor () [0x00077] in :0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x0001c] in :0
at System.Windows.Forms.XplatUI..cctor () [0x000e3] in :0
at System.Windows.Forms.Application.EnableVisualStyles () [0x00006] in :0
at .. (System.String[] ) [0x0002d] in <868b174b35bf46d7860f868d305a3a08>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
Restoring environment...
TopUser2000 12/13/2024 6:44:00 PM
#2 Posted: 12/13/2024 6:46:00 PM
TopUser2000
TopUser2000
0 likes in 28 posts.
I have the same problem on LM22 and sent this report to the developer many weeks ago but I haven't got any answer
#3 Posted: 12/14/2024 1:22:07 PM
Keith
Keith
1 likes in 3 posts.
Misery loves Company...
#4 Posted: 12/14/2024 7:56:54 PM
554 likes in 1333 posts.
This happens because libgdiplus in appimage has missing symlinks.
I added and recompiled appimage with libgdiplus symlinks added.
Now it works. I don't know why Andrev didn't add those links, who knows?
Download appimage linked below, I have tried with linuxmint_22 live iso.
SMathStudioDesktop.1.2.9038-x86_64-linuxmint_22.glibc2.35.AppImage.tar.gz (11 MiB) downloaded 115 time(s).
TopUser2000 12/16/2024 1:54:00 AM
#5 Posted: 12/15/2024 2:15:23 PM
Keith
Keith
1 likes in 3 posts.
That works great... Thanks a lot!
#6 Posted: 12/16/2024 2:18:17 AM
TopUser2000
TopUser2000
Thanks so much. Now it works.
Does the sMath author have any activity? No respond of email request or forum topic.
#7 Posted: 12/21/2024 6:49:02 PM
2270 likes in 3734 posts.
Hello.
Please, could you provide a script to create this appimage? We can integrate it into our build process and provide Mint v22 appimage package in future.
Thanks in advanced!
Best regards, Andrey Ivashov.
#8 Posted: 12/24/2024 12:36:37 AM
Hello.
Thanks in advanced!
I did extract content of original smath appimage from terminal via --appimage-extract argument.
Added libgif.so and symlinks for libgdiplus.
Mono library replacement shouldn't be necessary, only for just in case.
Andrey, you can take my appimage and extract its content.
Only smath file updates should be enough for new appimage creation.
#9 Posted: 12/24/2024 12:42:14 AM
Generally libgdiplus library is strictly depended on glibc version of system.
Usually it is creating the havoc, because of it also mono libraries too.
#10 Posted: 12/24/2024 4:01:30 AM
Thank you! Checking.
#11 Posted: 12/27/2024 2:33:48 AM
TopUser2000
TopUser2000
Could you fix the latest appImage?
#12 Posted: 12/27/2024 2:52:30 AM
What do you mean by fix?
The file I have uploaded should already works for linuxmint 22.
#13 Posted: 12/27/2024 2:54:23 AM
1417 likes in 2873 posts.
There is a new 1.3.0.9126 version
#14 Posted: 12/27/2024 2:57:16 AM
There is a new 1.3 version
Really? I didn't even update my SMath.
I am going to look it, post here when it is done.
Oscar Campo 12/27/2024 6:23:00 PM
#15 Posted: 12/27/2024 11:58:03 AM
I don't know if it is only on my pc but,
New version doesn't work on linux.
When any plugin is installed,
SMath crashes when reopened.
Going to inspect further...
#16 Posted: 12/27/2024 10:04:51 PM
There was some missing files for /usr/lib/mono and libgdiplus.so.
This should work now, please check it and report.
SMathStudioDesktop.1_3_0_9126.Mono.x86_64.linuxmint-22.glibc2.35.AppImage.tar.gz (11 MiB) downloaded 58 time(s).
SMathStudioDesktop.1_3_0_9126.Mono.x86_64.linuxmint-22.glibc2.35.AppImage.tar.gz (11 MiB) downloaded 103 time(s).
Oscar Campo 12/27/2024 10:25:00 PM, TopUser2000 12/28/2024 1:59:00 AM
#17 Posted: 12/28/2024 1:56:55 AM
TopUser2000
TopUser2000
it works even with XYplot plugin)
But some text can't be imaged like in the previous version
#18 Posted: 12/28/2024 2:15:50 AM
This version even works with ubuntu-24.04 along linuxmint-22.
I only added export MONO_WINFORMS_XIM_STYLE=disabled before exec mono.
It prevents a stupid mono bug keeping applications crash at start.
Change is applied to smath_launcher in appimage.
For the lacking of button texts, it is probably mono error.
Possibly I can't do anything about that.
Oscar Campo 12/28/2024 4:29:00 AM
  • New Posts New Posts
  • No New Posts No New Posts
