RC: SMath Studio 0.97.5301 (07 July 2014)
RC: SMath Studio 0.97.5301 (07 July 2014) - Messages
#1 Posted: 7/6/2014 4:41:32 PM
2270 likes in 3734 posts.
RC: SMath Studio 0.97.5301 available
Latest changes (against SMath Studio 0.97.5283)
  • SS-10: Critical simplification issue fixed (happens sometimes on complex math expressions);
  • SS-52: Support for sech() and csch() functions added to differentiation engine;
  • SS-89: Displaying of incorrect error message fixed for expressions with result shown right after definition;
  • SS-141: Critical error on Shift+Right Arrow at the end of the TextRegion;
  • Support for beta releases of extensions implemented;
  • Change units for C, F and Re non-linear units added to package;
  • Built-in variable added: lastError;
  • Behavior of combobox for changing font size improved;
  • DEV: Worksheet evaluation can be requested from mouse wheel event;
  • Stability improved;
  • Interface translations updated.
Download
4 users liked this post
Davide Carpi 7/6/2014 5:39:00 PM, Radovan Omorjan 7/6/2014 5:57:00 PM, ioan92 7/7/2014 3:18:00 AM, IVR 7/7/2014 1:35:00 PM
#2 Posted: 7/6/2014 6:01:39 PM
325 likes in 2052 posts.
Thank you Andrey
Finally we can use temperature changes now.
Davide Carpi 7/6/2014 9:15:00 PM
#3 Posted: 7/7/2014 12:13:26 PM
Igor Skarine
Igor Skarine
14 likes in 97 posts.
Hi Andrey,
I just tried my worksheet which has been working very well with version 097.5283, it doesn't work any more.
The reason is: MathcadEFI plugin from uni is now broken.
Igor
#4 Posted: 7/7/2014 5:46:07 PM
1222 likes in 2150 posts.
Hi Andrey,
Igor
Wait for an appropriate version appearing here and use that as executable instead of what the installer supplied.
Igor Skarine 7/7/2014 7:32:00 PM
#5 Posted: 7/7/2014 5:53:05 PM
We could use temperature changes in the past as well ;-) if we decided to stick to what is physically correct: use absolute units for them.
The new Delta units are good in that they suggest the more sloppy users that there might be a difference to care about.
Yet a major source of errors with offset-temperature units remains: the surprisingly low priority of the unary minus operator.
Radovan Omorjan 7/8/2014 2:40:00 AM
#6 Posted: 7/7/2014 7:30:58 PM
Igor Skarine
Igor Skarine
Thanks, Martin.
I just forgot to "fix" executable as I did for 0.97.5283.
#7 Posted: 7/8/2014 1:31:54 AM
Thanks, Martin.
How is the fix done? Usually, I take uni's 32bit version and add it to the portable package.
#8 Posted: 7/8/2014 4:31:58 AM
1402 likes in 1708 posts.
Thanks, Martin.
Kay always can do that.
Martin Kraska 7/8/2014 7:38:00 AM
#9 Posted: 7/8/2014 7:37:55 AM
Thanks, Martin.
Thanks uni, I just saw the screenshot in the EFI topic, thus one needs Visual Studio for changing the flag.
#10 Posted: 7/11/2014 9:11:11 AM
Did anyone experience this Unhandled exception when just trying to change the language interface. When ignoring it, then SMath appeared quite strange - see the picture. Also, see the video on this link changing languages problem (~5min long)
Here are the messages accompanied with this Unhandled Exception:
(x64 Win7)
Show Spoiler
#11 Posted: 7/11/2014 9:28:48 AM
1417 likes in 2873 posts.
mhhh... I can't replicate your issue, I've tried with a lot of languages. Have you customized some units xml file?
#12 Posted: 7/11/2014 10:33:00 AM
No, I did not do anything like this. Strange, but it happened to my home computer as well (x86 win7) and this nightly build. This happened when you I choose my languages (). It puzzled my more when I managed to use other languages but mine . On the other hand, I have no notification of the changes will have affect after restarting SMath when changing to Srpski or Српски contrary to other languages when I have this notification
Just to note, SMath portable by Martin (2014 06 21 SMath and Maxima) had no problems at all - see the picture.
Here is the Unhandled exception messages from my home computer.
Show Spoiler
#13 Posted: 7/11/2014 10:57:04 AM
Me too I've lost the message box, with any language, after some changes.
The portable distribution is from the previous Nightly Build, have you tried also unpacking the current linux archive? (SMathStudioDesktop.0_97_5301.Mono.tar.gz)
#14 Posted: 7/11/2014 11:23:38 AM
Yes, I did. It seems there is no problem with the portable version. On the other hand, I've noticed that at the Desktop (problematic) version my languages are on the top of the list???
#15 Posted: 7/11/2014 12:29:34 PM
I see, maybe this helps Andrey to understand where is the problem (my desktop build works like your portable build)...
#16 Posted: 7/11/2014 1:11:11 PM
I hope as well
#17 Posted: 7/11/2014 1:47:49 PM
Seems I found a problem. Radovan, please try to delete lang folder from C:\Users\[YOURPROFILE]\AppData\Roaming\SMath\extensions\.
Looks like it caused because this folder is not empty. I will handle it in next version.
Regards.
#18 Posted: 7/11/2014 2:18:07 PM
It seems you are right Andrey. The lang folder existed in Desktop extensions folder (guess which two files resisted there ) but not in the Portable extension one. I deleted the lang folder as you proposed and now it is all right . I might have figured out earlier, but I use Portable version more often.
Thank you,
#19 Posted: 7/11/2014 2:21:01 PM
Yes, looks like this is old bug which was not known by me. Now I understands the reason, so will completely fix it.
Thank you for your report!
Regards.
Radovan Omorjan 7/11/2014 3:10:00 PM
#20 Posted: 7/18/2014 11:26:01 AM
LitvincevYV
LitvincevYV
1 likes in 7 posts.
Ускорение свободного падения (и гравитационная постоянная) записывается и отображается некорректно
g
  • New Posts New Posts
  • No New Posts No New Posts
