How to input a group of matrix use for loop
How to input a group of matrix use for loop - matrix operation - Messages
#1 Posted: 4/29/2021 1:34:21 AM
hrwang
hrwang
0 likes in 8 posts.
I have say, 4 matrix, size of (nr, nz). I am trying to do initiation of these 4 matrix, vs, vb, Cs, Cb. In mathcad, you create a matrix of 4 column and 1 row, representing these 4 matrix, and initiate with for loop.
matrix initiate
Smath didn't show any errors. But when I tried to display the values of one matrix, say, vs=, nothing show up.
I thought Smath might treat all variables as global variable, so, I tried anther way:
2nd try
Then the error showed up, "requested matrix element doesn't exist".
Do I really have to create vs, vb, Cs, Cb before I initiate them?
It is a very simple problem, but I really need help.
By the way, the tutorial is slightly different from reality in "range". When I define for loop ranges, such as [for i "belong" 0..100], the tutorial shows using range2 to choose (0,100), the context will show as above, but the reality will show [for i "belong"[0..100]], a bracket was added. I hope I used the range function properly.
Thanks!
#2 Posted: 4/29/2021 1:59:20 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 likes in 1676 posts.
Hi. SMath matrix index starts at 1, not at 0. If you want to translate Mathcad code into SMath, try to use ORIGIN:=1 in Mathcad, because x[0] always gives an error in SMath.
#3 Posted: 4/29/2021 3:14:11 AM
hrwang
hrwang
0 likes in 8 posts.
Thanks a lot. Following your instructions, I started to initiate from 1, using the 2nd picture, instead of 0. It worked.
#4 Posted: 4/29/2021 8:04:10 AM
1418 likes in 2874 posts.
As side note, you might initialize you matrices even like this:
#5 Posted: 4/29/2021 11:05:37 AM
983 likes in 6866 posts.
That's what you have in my reply
  • New Posts New Posts
  • No New Posts No New Posts
