How to Hard Define a Variable with Combobox
How to Hard Define a Variable with Combobox - How to set a variable equal to a value as if manually input using a combobox - Messages
#1 Posted: 2/12/2016 11:19:12 PM
Ryan Freund
Ryan Freund
19 likes in 339 posts.
I like to use the ComboBoxList however there are issues with include() when assigning values from the comboboxlist. Is there a way to me "hard define" a variable after using the comboboxlist so that it is as if I 'manually' input the variable?
Thanks!!
#2 Posted: 2/12/2016 11:40:38 PM
983 likes in 6866 posts.
Interesting, but "Insert Combo box" crashes Smath 5346 ! ?
Davide Carpi 2/13/2016 7:25:00 AM
#3 Posted: 2/13/2016 7:50:44 AM
1417 likes in 2873 posts.
Thanks!!
As for now there aren't workarounds from user-side. Probably a dirty solution (DEV-side) would be to provide an access to the output values in the xml with an "hook tag" for include. However the content wouldn't be "dynamical".
Merci beaucoup Jean, bug confirmed, source of the pain found. I'll update the plugin ASAP.
#4 Posted: 2/13/2016 3:48:43 PM
Ryan Freund
Ryan Freund
I see, I'll keep watch for any updates.
Thanks!
  • New Posts New Posts
  • No New Posts No New Posts
