Removing units from a result / variable
Removing units from a result / variable - Messages
#1 Posted: 1/31/2020 8:10:12 AM
Zigor Marroquín Martínez
0 likes in 7 posts.
Hi all!
Maybe this is a stupid question, but I'm just starting with SMath.
I searched also in forums but didn't find a similar topic..
I perform my calculations in SMath using always units, very interesting and useful. But now I need just the number, the value without units. What I do now is just dividing it by '1' and the unit XD
Any other method or function more professional? :P
Thanks a lot!
Zigor
#2 Posted: 1/31/2020 8:33:28 AM
1222 likes in 2150 posts.
Hi all!
In fact, this is the only professional way to do it, because this way you can control and display the unit to be used. Just suppressing the unit would force the reader to make assumptions on what unit has been used to derive the numerical value. The experienced reader knows that always base units are used (e.g. for plotting) but it is better to explicitly specify them.
#3 Posted: 1/31/2020 9:02:40 AM
0 likes in 7 posts.
Thanks, Martin..
It's exactly the way I work.
But now I want to export data to an Excel sheet, and afterwards to treat that data as numbers without unit (Excel works like that).. so instead removing the unit in Excel, I was just wondering if in SMath would be a function to do it before exporting
Best regards,
Zigor
#4 Posted: 1/31/2020 9:30:23 AM
Assuming you have a table with columnwise uniform units, then the following approach provides full control:
exportdata.sm (4 KiB) downloaded 62 time(s).
Alvaro Diaz Falconi 2/1/2020 4:59:00 PM
#5 Posted: 1/31/2020 11:51:27 AM
983 likes in 6866 posts.
That is incoherent with unitless maths.
1. It can't be QA whereas the unit system sub-processes.
2. Advanced maths [symbolic, solvers ..] don't take units.
... I'm immune to "thunder" from contradictory comments !
Engineering formulas are already given in corresponding units [SI , ...]
#6 Posted: 1/31/2020 12:07:07 PM
... or construct wrt the units you want.
... export table w/o header
Inst_Colebrook Pipe Data.sm (61 KiB) downloaded 79 time(s).
#7 Posted: 1/31/2020 1:00:29 PM
1. Vincenti is coded 'km' superb
2. Arc length is unary maths ... make it user c/w unit.
Angle Vincenty Earth Distance [Mike].sm (40 KiB) downloaded 69 time(s).
Integrate Compendium_4 ArcLength Parabola-Cubic.sm (20 KiB) downloaded 68 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
