[SS-3567] File corrupted after using region protection option
[SS-3567] File corrupted after using region protection option - Messages
#1 Posted: 10/3/2018 1:07:21 PM
cecile
cecile
0 likes in 7 posts.
I used protection regions on my smath sheet. Everything went fine until I close the sheet and try to reopen it. I can't expand areas no more (no "+" or "-" available anymore at the begining of the area), nor can I run calculations...
The file seems corrupted. It weights only 20kB...
Someone help please!
File is available here :corrupted file.sm (20 KiB) downloaded 64 time(s)..
Thanks a lot
#2 Posted: 10/3/2018 2:28:12 PM
1417 likes in 2873 posts.
Confirmed and reproduced; (also, reproducible using copy and paste on opened worksheets).
Unfortunately everything in the protected area is lost (not saved, hence not recoverable).
Bug reported as SS-3567.
#3 Posted: 10/4/2018 4:24:57 AM
cecile
cecile
0 likes in 7 posts.
Thank you for having a look at it anyway.
#4 Posted: 10/4/2018 7:05:14 AM
Thank you for reporting; as posted in the BTS the issue is fixed now and will be part of the next release.
#5 Posted: 7/14/2022 11:21:58 PM
oscar mauricio
oscar mauricio
1 likes in 10 posts.
Hi, I find a similar error when I use region protection and secondary areas are contained in the area.
When opening the sheet all content is protected
I hope it could be improved in future versions.
  • New Posts New Posts
  • No New Posts No New Posts
