Unable to open sm file
Unable to open sm file - Messages
#1 Posted: 2/26/2021 1:52:59 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
While making finishing touches to the attached SM file (latest version), a warning message
propped up to continue or quit. I continued, saved and closed.
But now unable to open it. It loads but immediately closes without any message.
Can this be recovered please?
This is the first time I came across this type of an issue.
I use latest WIN 10 64 bit Home edition
TEST.sm (387 KiB) downloaded 64 time(s).
#2 Posted: 2/26/2021 2:22:14 PM
554 likes in 1333 posts.
For information, same behavior with bug under Linux.
Seems a line break is written wrong to file.
Corrected it with text editor and tried to save under smath to replicate the bug.
Couldn't achieve to bug reappear again.
Code was like this previously.
<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>
Revised to this with text editor.
<p>EE<br />Calculate the head losses and the corrected fows in the various pipes of a</p>
TEST_rcv.sm (488 KiB) downloaded 60 time(s).
#3 Posted: 2/26/2021 2:41:00 PM
NDTM Amarasekera
NDTM Amarasekera
Corrected it and tried to save to replicate the bug.
Thank you very much for your contribution.
It saved me a lot of trouble.
#4 Posted: 2/26/2021 9:01:16 PM
You are welcome, happy to help you.
#5 Posted: 2/27/2021 12:18:02 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
I've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct.
NDTM, I spotted what appears to be minor spelling error. FLOWS, not FOWS
#6 Posted: 2/27/2021 12:30:47 PM
NDTM Amarasekera
NDTM Amarasekera
Yes. Thank you. Now I made the correction.
#7 Posted: 3/1/2021 1:31:58 AM
NDTM Amarasekera
NDTM Amarasekera
Whenever I try to edit contents of some description boxes the unhandled exception error message props up. For information of Developers please.
#8 Posted: 3/1/2021 7:41:53 AM
1417 likes in 2873 posts.
Please attache the content of the "Details" window.
IDK I'm only an amateur HTML coder but to me
always has been a void/empty element; looking at standards:
In the orginal HTML (up to 4.01) only
is correct;
In XHTML
and
are allowed,
is not allowed.
In HTML 5 only
and
are allowed,
is not allowed.
something
was newer allowed, so it seems an encoding bug to me.
#9 Posted: 3/1/2021 12:25:09 PM
NDTM Amarasekera
NDTM Amarasekera
Details Window.txt (30 KiB) downloaded 42 time(s).
Pipe_Network_EX_HARDY_CROSS.sm (299 KiB) downloaded 47 time(s).
#10 Posted: 3/4/2021 8:53:47 AM
2271 likes in 3734 posts.
Both issues fixed. Thank you!
#11 Posted: 3/5/2021 1:45:27 PM
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey!
#12 Posted: 3/25/2021 10:21:12 AM
JenniferCastillo
JenniferCastillo
0 likes in 4 posts.
Most accurate and informative answer.
  • New Posts New Posts
  • No New Posts No New Posts
