SMath Studio 0.98.6325 (26 April 2017)
SMath Studio 0.98.6325 (26 April 2017) - Messages
#1 Posted: 4/26/2017 4:03:46 PM
2270 likes in 3734 posts.
Changes introduced in current build 0.98.6325
Improvements
  • Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet;
  • SS-2430: Dynamic Assistance tooltips improved: description of the snippet is now shown, footer can be multiline now, functions without description handled correctly;
  • Worksheet opening performance improved for Regions with hidden input part;
  • Internal meta-data for Regions supported (within the program and worksheet files format).
Corrections
  • SS-2429: Loading of Worksheet files with self-closing REGION tag(s) fixed;
  • Document title corrected on printing (important for some printers).
Miscellaneous
  • SS-2290: DEV: IPluginToolboxGroups implemented;
  • DEV: Initial support for Menu Extenders plug-ins added (IPluginMenuExtender - for always visible items in context menu only);
  • DEV: Added ability to remove definitions from the global context;
  • Refactoring.
Download
SMathStudioDesktop.0_98_6325.Mono.tar.gz (1 MiB) downloaded 832 time(s).
SMathStudioDesktop.0_98_6325.Setup.msi (2 MiB) downloaded 2782 time(s).
10 users liked this post
sergio 4/26/2017 4:42:00 PM, Arie 4/26/2017 4:52:00 PM, Davide Carpi 4/26/2017 7:15:00 PM, frapuano 4/27/2017 1:33:00 AM, Radovan Omorjan 4/27/2017 3:12:00 AM, Mikaël 4/27/2017 6:57:00 AM, IVR 4/27/2017 7:27:00 AM, Вячеслав Мезенцев 4/27/2017 12:03:00 PM, NDTM Amarasekera 4/28/2017 4:19:00 AM, Martin Kraska 4/29/2017 9:04:00 AM
#2 Posted: 4/28/2017 7:34:42 AM
1417 likes in 2873 posts.
Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards)
#3 Posted: 4/28/2017 11:08:31 AM
karlashnikov
karlashnikov
1 likes in 2 posts.
Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
#4 Posted: 4/28/2017 1:00:09 PM
I guess you have to remove image region plugin.
#5 Posted: 4/28/2017 1:21:32 PM
karlashnikov
karlashnikov
1 likes in 2 posts.
Thank you, that's it!
Davide Carpi 4/28/2017 1:34:00 PM
#6 Posted: 4/29/2017 9:23:41 AM
1222 likes in 2150 posts.
Clear() doesn't work with vectorize(), whereas IsDefined() does.
It is not really essential to have that feature but the response indicates successful execution, which is wrong.
Clear.sm (29 KiB) downloaded 96 time(s).
IVR 4/29/2017 2:52:00 PM
#7 Posted: 4/30/2017 7:38:29 PM
983 likes in 6866 posts.
Hello Martin,
Clear(,)=1 looks a Matlab code that clears the work space
from previous assigned values. Thus, it renders the algorithm
of the "work space" scalar wrt their respective scalar running
iterators x, y ...
In the attached "Fourier Quantum"... x,y are returned scalar
only for the double integrator. The Mathcad double integrator
is coded implicit of 'x,y' scalar ... much simpler but less
educative.
Fourier Quantum CoC Copy.sm (97 KiB) downloaded 97 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
