Stable: SMath Studio 0.78 (01 March 2009) - Messages
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
QuoteControls:
With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second.-
With consecutive pushing of this button you can choose: "number related to the button", "symbols related to this button". To lock any variant just stop pushing this button 1 second.
With consecutive pushing of this button you can choose: "plus operator", "minus operator", "multiplication operator", "division operator", "exponentiation operator", "plus/minus operator", "factorial", "vector multiplication operator". Also with this pushed button you can highlight the part of equation by using Left/Right buttons.
By "clicking" on this button program will numerically calculate equation (this means "="); by pushing button more than 0,4 sec. program will symbolically calculate equation (this means "->"). Also, if the cursor located on the right of the not defined variable or not defined function this button will create a definition operator (this means ":=" ).
Removing last character (Backspace). In the mathematical reference book this button means "Back".
- SMath Studio now supports Mathcad files to open (files with .xmcd extension)!
- Desktop: Dynamic cursor changes implemented (on the bounds of the controls, on resizing, on moving etc...);
- Added ability to Undo/Redo for the hole page instead of the separate history for every control;
- Selecting page controls with Ctrl key pressed implemented;
- Desktop: Ctrl+M (Open Insert Matrix dialog), Ctrl+E (open Insert Function dialog) and Ctrl+T (insert picture control) shortcuts added;
- To start writing a text " (quotes) button can be pressed;
- Desktop: PI constant now can be inserted with a shortcut: Ctrl+Shift+P;
- Desktop: Added ability to Zoom graphs by mouse wheel;
- Desktop: added Drag & Drop ability to open files from the outside;
- Desktop: Window params now save on programe close (such as: size and location);
- Improved simplification of the functions ln(x) and lg(x) in case of the x-numbers are equal e (for ln) or 10^c (for lg);
- Trigonometric functions with standard values in deg. now can be simplified;
- Min required numbers changed from 10e-12 to 10e-99;
- Fixed error with Plot control: sometimes it can't be resized.
- sec() and cosec() [csc()] functions simplification ability added;
- Numeric library improved to exclude some calculating errors;
- identity(), matrix(), rows(), cols(), el(), length(), tr() functions implemented into symbolic library;
- Vector multiplication (cross product) operator added to symbolic library for native support;
- Loops (for, while) performance improved;
- All symbolic calculations results now displays all fractional powers as radicals;
- German interface translation updated;
- Fixed error: calculation results not updates after using Undo/Redo functionality;
- Handheld: Fixed error with various matrix Toolbar button modes on non-cyrillic devices;
- Corrected file names of opened pages on the main program Title;
- Fixed paths for the result html-file on Export to HTML action (especially for Linux version);
- Graphs improved (summ() function now work into the control);
- Border supporting added to SMath Studio controls;
- Handheld: Fixed error when user "Save as" file without filling extension in File Name input - this file can rewrite existent one without any confirmation dialog;
- Desktop: Fixed errors with Save-On-Close dialogs;
- Text Control now can be removed by removing all it's text;
- Fixed "Esc = Backspace" issue;
- Desktop: 3D plot accuracy increased;
- Fixed critical error, when Plot graphs with large z-coordinate;
- Update dialog now can be setted up to check for stable updates only;
- Couple of errors in symbolic library fixed;
- Speed and stability improved;
- Code optimizations.
- Handheld:
Framework: .NET Compact Framework 2.0 cab (5,33МБ), zip (1,99МБ)
Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, full VGA support, all PPC's, Comunicators and smartphones. - Desktop (Windows):
Framework: .NET Framework 2.0 - Desktop (Linux):
Framework: Mono 2.0
Desktop и Handheld (18 languages):
- Handheld (PPC, Communicator, Smartphone):
SMathStudioHandheld.0_78.Setup.cab (Date: 01.03.2009. File size: 1,2MB) - * To install from the device
SMathStudioHandheld.0_78.Setup.cab.zip (Date: 01.03.2009. File size: 281,38KB) - * To install from the device (archive with CAB inside)
SMathStudioHandheld.0_78.Setup.exe (Date: 01.03.2009. File size: 357,56KB) - To install from the PC
SMathStudioDesktop.0_78.Setup.msi (Date: 01.03.2009. File size: 651KB)
- Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_78.Mono.tar.gz (Date: 01.03.2009. File size: 303,41KB) - last version of Mono distributive required!
* For installation of the program from PPC it is necessary to transfer a file on Your handheld computer (for example, with MS ActiveSync) and start it there with Your file manager.
** For installation of the program from PC it is necessary to install MS ActiveSync first.
New Posts
No New Posts
