Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Messages
#181 Posted: 5/23/2021 7:44:04 AM
1417 likes in 2873 posts.
PLUGIN UPDATED SMath Studio 0.99.7808 and later
  • fixed encoding/decoding issues;
  • refactoring;
#182 Posted: 8/5/2021 10:04:01 AM
Stefano
Stefano
0 likes in 22 posts.
when saving as odt with the option to convert to libreoffice math object, negative quantities loose the minus sign only if the haven't any other element in front of them. For example:
Quote
a:=4-9=-5
it get converted to
Quote
a:=4-9=5
For context, I just discovered this app so it could be that I am simply ignoring something obvious.
File not found.->File not found.
#183 Posted: 8/5/2021 5:25:52 PM
Seems a bug in the plugin, thank you for reporting it
#184 Posted: 12/24/2021 1:52:45 AM
susilo widyatmoko
susilo widyatmoko
3 likes in 8 posts.
can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
#185 Posted: 12/29/2021 8:16:47 PM
Hello [userlink]Susilo Widyatmoko[/userlink],
Yes, you can. If you want to let the user choose a path, there is the path picker region, otherwise you might choose a default output, f.e. if you choose an empty string as third argument ("") the file will be created next to the executable.
#186 Posted: 6/3/2022 8:56:14 AM
RaiHil
RaiHil
0 likes in 2 posts.
Hello Davide,
thank You for Your very useful Plug-in!
I use it regularly to paste my Smath calculations into MS Word.
In order to be able to arrange and organize formulas and text better, I use text regions.
Unfortunately, text regions containing formulas are not saved properly in the *.odt files.
Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files?
Thank You verry much
Raimund
#187 Posted: 6/6/2022 1:51:47 PM
Hello [userlink]RaiHil[/userlink]
I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side.
#188 Posted: 6/9/2022 11:52:55 AM
RaiHil
RaiHil
0 likes in 2 posts.
Thank you, I appreciate your effort!
  • New Posts New Posts
  • No New Posts No New Posts
