Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Messages
#101 Posted: 5/2/2013 5:31:53 PM
kilele
kilele
133 likes in 397 posts.
I've just tried Martin's distro with the full plugin and got the same error as you, everything is broken (all samples in docs' plugin) with the same ionic.zip error.
Curiously enough, I think that this didn't happened in Linux (it worked only export correctly) but I want to do more tests in Linux.
edit:
yes i had a plugin disabled when starting smath but dont know which one yet. i'll edit this post later on.
#102 Posted: 5/2/2013 5:42:13 PM
1417 likes in 2873 posts.
Hi Radovan
The Full Package issue is caused by the ClosedXML library when SMath loads the plugins in the "Plugin" folder (if you put only the ClosedXML.dll file inside the plugin folder of a clean installation the message will appear), the OpenDocument issue by the Ionic.Zip library calling the related functions, I don't know if the 2 bugs are the same or simply similar...
It seems that Martin did not have this problem o_o
I don't know...
An early Post probably related: Issue SMATH Error - Won't Load Existing XMCD File (Build 0.96.4868) - XMCD File created by previous version will not open in new version
#103 Posted: 5/2/2013 5:59:06 PM
325 likes in 2052 posts.
edit:
I tried it as well in Xubuntu using Martins' version. No errors about Ionic.zip. Save as ODT is working, but it seems that only the text can be saved. I did not manage to save formulas and plots.
#104 Posted: 5/2/2013 6:11:51 PM
1222 likes in 2150 posts.
I had a closer look at the DataExchange plugin under 0.96. For now, I see the XeTeX and csv export working fine, others still have to be checked, but there are problems in the example files. Unfortunately, I am not keeping pace with the flood of updates in the forum, thus it will take a while until distro and handbook will have settled and updated. Currently, I am just focussing on bug reports and test feedback.
#105 Posted: 5/2/2013 6:24:56 PM
Hello Davide,
I do not know why some of your post have to be approved sometimes
Hi Radovan
I don't know...
Sorry, I forgot that ClosedXML thing . Martin mentioned it few times.
#106 Posted: 5/3/2013 3:28:59 AM
kilele
kilele
Please download this file to see my test on SolusOS Linux,
Repository: Debian Stable; Desktop manager: Gnome2.3, btw SMath is very responsive in this manager.
This file contains the plugin docs and some screenshots showing errors while running the program.
An this is the plugin tested in Zorin(ubuntu)
http://www.mediafire.com/?p4ehqsr6pgs2vwl
Davide Carpi 5/3/2013 4:52:00 AM
#107 Posted: 5/3/2013 2:43:29 PM
Hi Radovan
I don't know...
Just to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it.
By the way, the activity on the Forum increased quite a lot, almost hard to follow . I am not complaining, just contrary
Davide Carpi 5/3/2013 2:50:00 PM
#108 Posted: 5/3/2013 2:54:15 PM
1402 likes in 1708 posts.
If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody ):
Show Spoiler
Davide Carpi 5/6/2013 3:36:00 AM
#109 Posted: 5/3/2013 3:25:34 PM
#110 Posted: 5/3/2013 5:56:30 PM
Thank you uni, this workaround solve all the issues
BTW this make dirty the SMath's installation folder, so it's really better to not use it if not strictly required.
best regards,
w3b5urf3r
#111 Posted: 5/3/2013 6:15:42 PM
It does not work for me, or I did not figure out . Never mind, I hope that will work for most of the users
#112 Posted: 5/7/2013 7:29:57 PM
PLUGIN UPDATED
- change of requirements: SMath Studio 0.96.4875 (07 May 2012)
- relative path improvements;
- ODS export vs symbolic optimization fix;
- patch on ODT embedded images for Linux users;
- SMath Viewer compatible.
best regards,
w3b5urf3r
ioan92 5/8/2013 3:45:00 AM
#113 Posted: 5/8/2013 1:12:28 AM
Steve Swinbanks
Steve Swinbanks
2 likes in 11 posts.
Thanks. Seems to work fine now.
Steve
#114 Posted: 5/8/2013 5:41:30 AM
Steve
You're welcome :d
#115 Posted: 6/10/2013 3:41:09 AM
PLUGIN UPDATED
- XLSX features moved away (see Xlsx Import/Export plugin )
- plugin added to the Gallery (Latest Nigthly build)
- Added Guid (after installing the plugin, a message should appear opening old files, just skip it and save again the file)
best regards,
Davide
4 users liked this post
Вячеслав Мезенцев 6/10/2013 6:40:00 AM, IVR 6/10/2013 3:34:00 PM, ioan92 6/10/2013 4:11:00 AM, Radovan Omorjan 6/10/2013 3:56:00 AM
#116 Posted: 9/17/2013 1:10:04 PM
UPDATED (Gallery only)
- fixed: SMath Studio 0.96.4909 (10 June 2013) vs XeLaTeX saves
#117 Posted: 12/30/2013 7:53:11 AM
paolo1963
paolo1963
1 likes in 4 posts.
when the program starts, the following message appears
operating system Win 7
smath versione 096 4868
net framework 4.5.1
#118 Posted: 12/30/2013 9:47:42 AM
Hi Paolo,
I can't reproduce your issue (win7 x64 - SMath 0.96.4909)
Are you sure that this plugin cause the issue? copy and paste the red string ( %APPDATA%\smath\extensions\plugins ) in your windows start menu, press the return key and then delete the plugin folder (5dce7298-9e5f-4120-9a2e-49b16daa02a3) then try to start SMath again.
Davide
#119 Posted: 12/30/2013 3:11:25 PM
paolo1963
paolo1963
1 likes in 4 posts.
I uninstalled the version of SMath 096 4868 and I installed version 096 4909 now the program starts.
Save in *. odt work,
while saving in *. tex from the following error message:
#120 Posted: 1/3/2014 8:56:45 PM
Really strange, I can't reproduce this issue
The problem is related to some worksheet (empty file, with figures, with text, with math), some machine, or is general?
Have you the same issues with the unofficial portable version?
You could try to share here your system informations (Development Tools plugin > System informations > save as... > attach here the file)
  • New Posts New Posts
  • No New Posts No New Posts
