1 Pages (5 items)
Some bugs calling composite functions with if() or cases() - Messages
#1 Posted: 11/18/2020 2:25:14 PM
Hi. I don't know if this is a know one. I guess they are related to the fact that functions with if can neither be derived nor integrated. Notice that seems that there are a bug in cases() too.
FunctionBug.sm (13 KiB) downloaded 58 time(s).
FunctionBug.pdf (48 KiB) downloaded 63 time(s).
sergio 11/18/2020 3:27:00 PM
#2 Posted: 11/18/2020 4:21:23 PM
... and issues in composite functions with loops.
FunctionBug2.sm (17 KiB) downloaded 61 time(s).
FunctionBug2.pdf (76 KiB) downloaded 56 time(s).
sergio 11/18/2020 4:45:00 PM
#3 Posted: 11/18/2020 4:47:05 PM
Wrote... and issues in composite functions with loops.
Debugging with trace(), what I see is that when calling g, f takes phi=1, (this is the first phi=1 in the output window) but don't do the loop. Calling f isolated shows another phi=1 and subsequent values for phi.
With for(3) gives an error, so I can't debug that. Additionally, calling with for(4) seems to have the same behavior than while.
#4 Posted: 11/18/2020 5:48:24 PM
WroteI don't know if this is a know one. I guess they are related to the fact that functions with if can neither be derived nor integrated. Notice that seems that there are a bug in cases() too.
1. You must assign "cases" like in your last example.
2. Before Davide introduced "cases" it was a damned job integrate
unless from discrete finite differences like in the old days.
The min(x) style [undocumented] is quite smart, mostly OK Simpson.
Integrate Discontinuous [min(x)].sm (16 KiB) downloaded 58 time(s).
#5 Posted: 11/19/2020 8:30:09 AM
As I've already mentioned here and there, assignments shouldn't be made inside cases() arguments, because:
This is a downside that currently can't be prevented. As you can see making the assignment outside cases() works as expected.
WrotePlease be careful however, since a symbolic evaluation to show the function content or a failed evaluation with an error triggered on the conditions leads to the evalution of all the options.
In general currently is better to use cases to host just dead content (numbers, strings, variables).
1 Pages (5 items)
New Posts
No New Posts
