.xmcd => .ms integral
.xmcd => .ms integral - struktron - Messages
#1 Posted: 8/18/2013 6:19:36 AM
struktron
struktron
0 likes in 7 posts.
I am new and my English is bad. I wood like to transform my
http://struktron.de/FSK/Feinstrukturkonstante.xmcd
to
http://struktron.de/FSK/Test-FSK.sm
My (18), integral with sqrt, I can't solve. What can I do? Is it impossible?
Thanks for solution or suggestion,
Lothar W.
Do collisions of spheres generate the fine structure constant? http://struktron.de/FSK/Feinstrukturkonstante-Berechnung.html
#2 Posted: 8/18/2013 7:43:57 AM
1222 likes in 2150 posts.
I can't see an equation (18) in either of the files (xmcd opened with SMath). I don't know of problems with integral and sqrt, but there are definitely porblems with integrating over functions defined using if(), see attachment.
Section math integration units.sm (19 KiB) downloaded 67 time(s).
#3 Posted: 8/18/2013 8:30:45 AM
struktron
struktron
0 likes in 7 posts.
thanks for quick answer.
My first problem is, that I can't open my .xmcd in SMath Studio. There is a mistake in German:
Die Datei oder Assembly "TextRegion, Version=1.9.4868.42191, Culture=neutral, PublicKeyToken=null" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
My system is Windows Vista.
Did You open my http://struktron.de/FSK/Feinstrukturkonstante.xmcd with SMath and how?
My (18) is a definition for the function G(U,V,beta). In the integral I need, that U and V are numbers and beta a variable.
Lothar W.
#4 Posted: 8/18/2013 8:45:40 AM
You probably have the Cephes math plugin installed, at least your error message is typical for the problems it causes. See this post and the messages around it for details.
You also might try the inofficial distribution. It is portable and stores it's settings and extensions separately from the SMath version installed via Windows installer. It also comes with an extensive, yet very incomplete bilingual german/english handbook (pages of which I attached to the previous post).
See the printout of the imported xmcd file in SMath in the attachment.
fk.pdf (174 KiB) downloaded 65 time(s).
#5 Posted: 8/18/2013 10:19:03 AM
struktron
struktron
0 likes in 7 posts.
thank You very much for the portable version. With it I can open my .xmcd. The well known problems with text I know from Your very good handbook.
In my Test-FSK.sm I have the problem in (18) also with Your distribution (int( , , , ) - die Funktion ist nicht bestimmt).
My wish is, to give people a free program for testing my hypotheses. How could I solve that?
Discussions we have on ALLTOPIC.
Lothar W.
#6 Posted: 8/18/2013 10:25:09 AM
1. Import the file and rework manually
2. (Off topic here) Import to Mathcad Prime Express. You need the full version to do so.
Edit: The Test-FSK.sm has equations only up to (13)
Edit: Give a hint, how the function should look like. Is it possible to input it manually?
#7 Posted: 8/18/2013 12:12:32 PM
struktron
struktron
0 likes in 7 posts.
Now I have it up to up to (18) in my Test-FSK.
My question: can I take functions like in Mathcad, with variable limits of integrals?
Thanks and regards
Lothar W.
#8 Posted: 8/18/2013 12:29:19 PM
My question: can I take functions like in Mathcad, with variable limits of integrals?Thanks and regards
Lothar W.
Just rename the dummy integration variable. Integral limit and dummy variable should not have the same name (That's not a software limit but a math rule).
Edit: Hint added to handbook page.
Section Math Integrals.sm (29 KiB) downloaded 58 time(s).
#9 Posted: 8/18/2013 2:22:12 PM
struktron
struktron
0 likes in 7 posts.
Lothar W.
Thank You very much. I knowed it, but was blind for it. Now I have many to do, but the summer ...
Lothar W.
(thanks butten in forum dosn't work)
  • New Posts New Posts
  • No New Posts No New Posts
