Normal/Gaussian Function or Method: Normal Probability Density
Normal/Gaussian Function or Method: Normal Probability Density - Messages
#1 Posted: 1/6/2023 7:08:49 PM
Mark R Harris
Mark R Harris
4 likes in 90 posts.
This matrix generator (thanks gUrrozEN) produces random 'equal-probability' values for a given center value and tolerance band.
I'm hoping to revise this to return values within a normal/Gaussian probability as illustrated:
Random to Normal.sm (42 KiB) downloaded 66 time(s).
Any thoughts?
#2 Posted: 1/6/2023 10:47:00 PM
983 likes in 6866 posts.
Any thoughts ?
Native Smath plugins generate uniform randoms.
The Central Theorem proves that enough uniform randoms
generate a Normal Distribution.
You simply need to bin in an histogram utility.
Is that is what you are looking for ?
Otherwise, I don't understand your request.
#3 Posted: 1/7/2023 2:07:39 AM
Mark R Harris
Mark R Harris
Thank you for the reply Jean.
I'm after a method or function that will return a random value with the probability that 68.2% of the time it will be within 1 sigma, and 95.4% of the time it will be within 2 sigmas, etc.
#4 Posted: 1/7/2023 4:13:06 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 likes in 1676 posts.
Hi. For 'convert' random uniform distributed numbers between 0 and 1 to another probability distribution, in your case, for get some normal distributed numbers you can use the inverses of the cdf distributions. You can check that here for 1000 numbers you have the desired mean and std deviation
so, I guess that in your function rmat this is the function for normal distributed numbers
random to nomral.sm (5 KiB) downloaded 75 time(s).
Mark R Harris 1/7/2023 5:25:00 AM
#5 Posted: 1/7/2023 5:32:57 AM
Mark R Harris
Mark R Harris
Thanks Alvaro, very greatly appreciated.
For me, the sample file has a problem:
#6 Posted: 1/7/2023 5:55:38 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. I mean: substitute that M[i,j] into your rmat(...) function for get normal distributed numbers with the rmat algorithm instad uniform distributed ones.
Mark R Harris 1/7/2023 6:22:00 AM
#7 Posted: 1/7/2023 11:22:38 AM
I don't understand completely ... sorry.
However, from a native random sigma, you can solve for a desired other one.
Cheers, be good Down Under ... Jean.
Random NORMAL Histogram Copy.sm (44 KiB) downloaded 70 time(s).
#8 Posted: 1/7/2023 3:44:13 PM
Mark R Harris
Mark R Harris
Thank you both. Alvaro: perfect, thank you.
Here is the working update:
20230109 Random to Normal.sm (54 KiB) downloaded 73 time(s).
#9 Posted: 1/9/2023 1:41:49 AM
Mark R Harris
Mark R Harris
See the updated post above.
#10 Posted: 1/9/2023 12:44:09 PM
20230109 Random to Normal_1.sm (81 KiB) downloaded 71 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
