Operation with units xy2pol
Operation with units xy2pol - Messages
#1 Posted: 6/5/2016 12:07:03 AM
Basile
Basile
8 likes in 172 posts.
The xy2pol looks that still has problems with units:
Basile
#2 Posted: 6/5/2016 1:34:47 PM
983 likes in 6866 posts.
#3 Posted: 6/5/2016 1:53:42 PM
Basile
Basile
Jean,
In your example:
The Magnitude (length) and The Angle (angle) in polar coordinates have different units. The rad is not a common unit. It is not correct.
In my example:
Look again please:
This was solved in recent upgrade by Andrey but apparently remains in the xy2pol.
http://en.smath.info/forum/yaf_postst7552_Units--Operation-cannot-be-performed.aspx
Basile
#4 Posted: 6/5/2016 3:14:46 PM
Better be in harmony wth the maths and Smath.
There is nothing to look gain, Smath is OK.
For sure they have different units: one is in "UnitGraph" the other is in "rad"
YES: rad is correct, rad is the maths unit in trig approximations as well as in official tables.
If you want °: convert by appending ° in the Smath result
#5 Posted: 6/5/2016 5:22:05 PM
Basile
Basile
Jean,
1.
Please go previously and see the picture.
"rad" is the unit for both the magnitude and angle.
There is ONE placeholder for ONE unit.
YES: rad is correct, [YOU JUST SAID THAT ONE IS LENGTH THE OTHER ANGLE!!!] rad is the maths unit in trig approximations as well as in official tables.
2.
In this specific set of applications I have no interest in "numerical MathEMATICS". I use units. Thank you.
Basile
#6 Posted: 6/5/2016 5:38:16 PM
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
@Basile,
Just show what you are trying to describe verbally
Not that it would convince anyone who doesn't wish, though.
С уважением, Михаил Каганский
Davide Carpi 6/7/2016 5:28:00 PM
#7 Posted: 6/5/2016 5:52:10 PM
Basile
Basile
Mike,
The xy2pol does not work when units are included:
Do we agree?
When eventually it is working:
The units of the "Magnitude" and the units of the angle, (for the case of complex numbers here), will be different.
Note: I see you got W(att) how?
I see that you have a semicolon ( ; ) I have a comma (,).
Re(S);Im(S) versus Re(S),Im(S)
Basile
#8 Posted: 6/5/2016 7:26:10 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Something like that?
Notice that atan2 ins't in SMath, which is more correct than atan for this functions (see http://www.mathworks.com/help/matlab/ref/atan2.html for example).
Davide Carpi 6/5/2016 7:28:00 PM
#9 Posted: 6/5/2016 7:55:50 PM
Mike Kaganski
Mike Kaganski
Mike,
Do we agree?
Yes we do
Quote
Yes, that's what I show in my screenshot, that uses ≡ instead of =, just to show the desired result: seeing is better than reading.
Quote
Now I suppose it's apparent: Ctrl+= and manually make system with desired result
Quote
Russian locale default settings
#10 Posted: 6/5/2016 7:57:34 PM
In this specific set of applications I have no interest in "numerical MathEMATICS". [Basile]
From A...Z, Smath is a numerical math tool as any other CAS and including your specific application.
xy2pol result is a vector of two components that need no unit as they are implicit. Extract each
component and append a dead unit decoration for clarity to yourself and the reader.
#11 Posted: 6/5/2016 8:03:39 PM
Mike Kaganski
Mike Kaganski
atan2.sm (35 KiB) downloaded 65 time(s).
#12 Posted: 6/5/2016 8:58:58 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Mike. I prefer this other, but have some round inconvenients:
#13 Posted: 6/5/2016 9:04:35 PM
Mike Kaganski
Mike Kaganski
I guess that with the new try function samebody can make a good one atan2.
But with try, it won't differentiate again.
#14 Posted: 6/5/2016 9:10:02 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Oh, I think that this happen only to me :-). Not very sure that try don't accept diff.
So, this with numerical optimization must to be the best solution (until atan2 not be in SMath):
#15 Posted: 6/5/2016 9:24:33 PM
Mike Kaganski
Mike Kaganski
It's a good option, and only ~30% slower.
#16 Posted: 6/6/2016 10:11:40 AM
Like this Alvaro: look for the Matlb code in the f(x) menu,
look for mwatan2 ... if you have in your version: then go
Maths atan2.sm (10 KiB) downloaded 55 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
