DotNumerics
DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Messages
#21 Posted: 8/1/2018 12:54:24 PM
1402 likes in 1708 posts.
Simple test 2.
[albumimg]1499[/albumimg]
DotNumerics.ode.test2.sm (21 KiB) downloaded 87 time(s).
DotNumerics.ode.test2.pdf (79 KiB) downloaded 88 time(s).
sergio 8/1/2018 6:06:00 PM, Radovan Omorjan 8/2/2018 3:05:00 AM
#22 Posted: 8/1/2018 9:57:14 PM
983 likes in 6866 posts.
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24 KiB) downloaded 84 time(s).
#23 Posted: 9/9/2018 2:23:36 PM
1222 likes in 2150 posts.
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23 KiB) downloaded 119 time(s).
frapuano 9/9/2018 5:18:00 PM, Вячеслав Мезенцев 9/10/2018 5:37:00 AM
#24 Posted: 9/10/2018 6:48:25 AM
Updated for SS 0.99.6824. Intervals issue fixed.
sergio 9/10/2018 7:02:00 AM, frapuano 9/10/2018 9:23:00 AM, NDTM Amarasekera 9/10/2018 9:48:00 AM
#25 Posted: 12/6/2018 2:42:53 PM
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
#26 Posted: 12/24/2018 9:13:53 AM
Updated.
[albumimg]1564[/albumimg] [albumimg]1579[/albumimg] [albumimg]1580[/albumimg] [albumimg]1567[/albumimg] [albumimg]1566[/albumimg] [albumimg]1565[/albumimg]
dn.ode.kinetic1.sm (8 KiB) downloaded 142 time(s).
dn.ode.kinetic2.sm (12 KiB) downloaded 114 time(s).
dn.ode.kinetic3.sm (12 KiB) downloaded 114 time(s).
dn.ode.test1.sm (19 KiB) downloaded 126 time(s).
dn.ode.test2.sm (18 KiB) downloaded 120 time(s).
dn.ode.Amplitude detector.sm (20 KiB) downloaded 125 time(s).
dn.ode.kinetic1.pdf (77 KiB) downloaded 129 time(s).
dn.ode.kinetic2.pdf (93 KiB) downloaded 109 time(s).
dn.ode.kinetic3.pdf (91 KiB) downloaded 104 time(s).
dn.ode.test1.pdf (115 KiB) downloaded 111 time(s).
dn.ode.test2.pdf (120 KiB) downloaded 107 time(s).
dn.ode.Amplitude detector.pdf (148 KiB) downloaded 108 time(s).
4 users liked this post
NDTM Amarasekera 12/24/2018 9:44:00 AM, sergio 12/24/2018 11:04:00 AM, frapuano 12/24/2018 2:23:00 PM, Radovan Omorjan 12/24/2018 2:52:00 PM
#27 Posted: 12/25/2018 2:49:08 PM
Native works as well.
You can try rkfixedSteven.
#28 Posted: 12/25/2018 4:25:11 PM
frapuano 12/25/2018 7:01:00 PM
#29 Posted: 12/9/2021 9:10:25 AM
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
sergio 12/9/2021 11:40:00 AM
#30 Posted: 12/20/2021 4:18:13 PM
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 Posted: 8/21/2022 2:43:28 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8 KiB) downloaded 60 time(s).
#32 Posted: 8/22/2022 3:12:45 AM
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
sergio 8/22/2022 4:19:00 AM, Alvaro Diaz Falconi 8/23/2022 8:15:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
