DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Messages
#21 Posted: 8/1/2018 12:54:24 PM
Simple test 2.
[albumimg]1499[/albumimg]
DotNumerics.ode.test2.sm (21 KiB) downloaded 98 time(s).
DotNumerics.ode.test2.pdf (79 KiB) downloaded 93 time(s).
#22 Posted: 8/1/2018 9:57:14 PM
WroteSimple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24 KiB) downloaded 93 time(s).
#23 Posted: 9/9/2018 2:23:36 PM
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23 KiB) downloaded 125 time(s).
#24 Posted: 9/10/2018 6:48:25 AM
Updated for SS 0.99.6824. Intervals issue fixed.
#25 Posted: 12/6/2018 2:42:53 PM
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
Changes:
#26 Posted: 12/24/2018 9:13:53 AM
Updated.
[albumimg]1564[/albumimg] [albumimg]1579[/albumimg] [albumimg]1580[/albumimg] [albumimg]1567[/albumimg] [albumimg]1566[/albumimg] [albumimg]1565[/albumimg]
dn.ode.kinetic1.sm (8 KiB) downloaded 153 time(s).
dn.ode.kinetic2.sm (12 KiB) downloaded 117 time(s).
dn.ode.kinetic3.sm (12 KiB) downloaded 120 time(s).
dn.ode.test1.sm (19 KiB) downloaded 135 time(s).
dn.ode.test2.sm (18 KiB) downloaded 127 time(s).
dn.ode.Amplitude detector.sm (20 KiB) downloaded 134 time(s).
dn.ode.kinetic1.pdf (77 KiB) downloaded 137 time(s).
dn.ode.kinetic2.pdf (93 KiB) downloaded 120 time(s).
dn.ode.kinetic3.pdf (91 KiB) downloaded 115 time(s).
dn.ode.test1.pdf (115 KiB) downloaded 118 time(s).
dn.ode.test2.pdf (120 KiB) downloaded 114 time(s).
dn.ode.Amplitude detector.pdf (148 KiB) downloaded 116 time(s).
4 users liked this post
NDTM Amarasekera 12/24/2018 9:44:00 AM, sergio 12/24/2018 11:04:00 AM, frapuano 12/24/2018 2:23:00 PM, Radovan Omorjan 12/24/2018 2:52:00 PM
#27 Posted: 12/25/2018 2:49:08 PM
#30 Posted: 12/20/2021 4:18:13 PM
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 Posted: 8/21/2022 2:43:28 AM
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8 KiB) downloaded 70 time(s).
Вячеслав Мезенцев 8/22/2022 3:11:00 AM
New Posts
No New Posts
