Show the Orignal Units in Table Region
Show the Orignal Units in Table Region - Show the original units in the Table instead of the basic units of the International System - Messages
#1 Posted: 3/21/2018 4:01:53 PM
CBG
CBG
77 likes in 312 posts.
Will it be possible?
Units_Table.sm (7 KiB) downloaded 111 time(s).
Carlos
#2 Posted: 3/21/2018 4:51:14 PM
115 likes in 329 posts.
sets the header and units matrices
Davide Carpi 3/22/2018 8:17:00 AM
#3 Posted: 3/21/2018 8:22:36 PM
CBG
CBG
Thanks Sergio:
You made me remember the solution that Martin Kraska gave me, but I can not put a header on it.
Do you have any suggestion?
Units_Table_r2.sm (15 KiB) downloaded 127 time(s).
Carlos
#4 Posted: 3/22/2018 6:35:19 AM
I thought about this (string manipulation)
but num2strtransforms into fractions
#5 Posted: 3/22/2018 1:36:09 PM
983 likes in 6866 posts.
I prefer the way we did in 1987, collecting piles of fluids information.
Units_Table Preference.sm (12 KiB) downloaded 131 time(s).
#6 Posted: 3/22/2018 1:44:41 PM
1230 likes in 2155 posts.
Use var2str() from CustomFunctions instead
sergio 3/22/2018 2:07:00 PM, frapuano 3/22/2018 5:29:00 PM
#7 Posted: 3/22/2018 8:21:28 PM
CBG
CBG
Thank you very much to everyone for your help,
I already managed to make the table as I required it.
Units_Table_r3.sm (9 KiB) downloaded 129 time(s).
Carlos
frapuano 3/23/2018 4:14:00 AM, Davide Carpi 3/23/2018 6:38:00 AM
#8 Posted: 3/22/2018 11:20:16 PM
Thanks Carlos: gorgeous
#9 Posted: 6/26/2018 6:32:55 PM
wb.c
wb.c
26 likes in 156 posts.
CBG,
Using the unit summary to convert units back to original units doesn't work for temperature conversions. What you are doing with the units summary assumes the conversion is a factored multiplier. It works great for everything except temperature (or any other unit doesn't scale by a factored multiplier).
#10 Posted: 6/26/2018 9:28:04 PM
Just define those units.
#11 Posted: 6/26/2018 9:49:54 PM
wb.c
wb.c
Jean Giraud,
Maybe try something other than 20 deg?...
Version: 0.99(build: 6671)
#12 Posted: 6/26/2018 11:59:58 PM
You are quite right and there are two things here
1. As it looks, the °C can't be made user.
The unit system is grounded on 'K', bloody pest to me.
2. The other thing is the Shadow in context, a real bug.
It worked fine from Carlos original [by what coincidence ?]
Not changing the context, context reproduces. Changing context
and the all thing °C gets freaked. I observed that many times
in Smath. In fact, very problematic.
Thanks for this wise observation.
Table Region Carlos.sm (10 KiB) downloaded 103 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
