Empty stack with maple
Empty stack with maple - Empty stack with maple - Messages
#1 Posted: 7/4/2021 1:24:23 AM
Bruno Choquepata
Bruno Choquepata
0 likes in 5 posts.
Hi everyone
I have to try to solve this equation with maple and solve but I only get the result "Empty stack", Someone knows solve it?
Moment_Curvature relationship.sm (940 KiB) downloaded 70 time(s).
#2 Posted: 7/4/2021 1:41:23 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. It seems that you put kd( ... ) instead kd*( ... ) in the maple solver.
#3 Posted: 7/4/2021 2:17:03 AM
Bruno Choquepata
Bruno Choquepata
0 likes in 5 posts.
Alvaro thanks for you answer but
"kd" is the only value unknown
#4 Posted: 7/4/2021 2:24:47 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
In the first expression it is kd( ... ). In the second it is kd*( ... ). There the maple answer uses RootOf, I'm guess that because you have another issue in the expression. For instance A.s*Fy have units of Newtons, but the other part not.
Bruno Choquepata 7/4/2021 3:11:00 AM
#5 Posted: 7/4/2021 3:14:36 AM
Bruno Choquepata
Bruno Choquepata
0 likes in 5 posts.
Thanks a lot Alvaro
#6 Posted: 7/4/2021 9:29:55 AM
554 likes in 1333 posts.
Thanks a lot Alvaro
Alvaro is right.
Left side of equation is N (kg*m/s^2), right side is J (kg*m^2/s^2).
A dimension should be extra or missing in that equation.
Probably not correct solution but if you equate units;
#7 Posted: 7/4/2021 12:33:54 PM
983 likes in 6866 posts.
1. RootOf expands easily [Example 1]
2. root is undocumented, most precious for dual solver [Example 2]
3. allvalues ... most precious in invlaplace [Example 3]
Maple RootOf Example.sm (38 KiB) downloaded 71 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
