Changing Units
Changing Units - Messages
#1 Posted: 10/27/2017 11:58:25 AM
Paulius
Paulius
0 likes in 11 posts.
I have unis for example:
a=2MPa
b=2N/mm2
a+b=4*10e6 Pa
How can I obtain the answer in N/mm2, not in Pa. Is it possible. In Mathcad simple change the units, but it's a pity here it doesn't work. Thank You for reponse. Paulius
#2 Posted: 10/27/2017 12:44:47 PM
983 likes in 6866 posts.
Nmm²:=1 ....... a:= 2, b:=2 .... a+b=4Nmm²
#3 Posted: 10/27/2017 1:57:22 PM
CBG
CBG
77 likes in 312 posts.
See the Handbook in Tools--plugins--handbooks--Introduction to Smath Studio by Gilberto E. Urroz, page 17
Carlos
#4 Posted: 10/28/2017 7:51:22 AM
Paulius
Paulius
Thank You
#5 Posted: 10/29/2017 8:44:45 AM
Attached are two typical Engineering projects that don't use unit system.
Standards are given in the appropriate unit system. So, you just need to
append the "UnitResult" accordingly to the formulation.
"Uconeer" is a freeware unit conversion software from "Katmar".
From "Katmar" you can get WASP [Water and Steam Properties]
Free use for 2 min session.
On the other hand, Smath unit system has changed from Smath 5346 to
Smath 6179 ... that freaks many of my projects.
I started Mathsoft Collaboratory day 1 for over 125000 visits.
1000's projects were done [Engineering/Scientific], not a single one
was carried with units.
Inst_Colebrook Pipe Data.sm (59 KiB) downloaded 78 time(s).
Inst_Orifice Plate.sm (387 KiB) downloaded 71 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
