Transferring three-dimensional image on a two-dimensional graph
Transferring three-dimensional image on a two-dimensional graph - Ber7 - Messages
#1 Posted: 12/8/2013 11:51:06 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
This method was suggested by the author of the "Method of Draghilev" prof. Alexei Ivanov.
1.st through the matrix of three columns (x, y, z) to construct
3d graph and select the desired Rakurs;
2.Using linear coordinate transformations turn
all points of the matrix at an angle (angles) corresponding
Rakurs and obtain a new matrix;
3. Out of three columns of the new matrix choose two and
substitute them in 2d graph;
Animation shows two first surface constructed A.Ivashev second
V.Mezentsev (Bottom). The animation is done on a flat graph.
ButKlejn.smz (4 KiB) downloaded 175 time(s).
Davide Carpi 12/8/2013 1:36:00 PM
#2 Posted: 12/28/2013 3:47:32 PM
Fridel Selitsky
Fridel Selitsky
Updated.Fixed mistake in the first matrix coordinate transformation
Davide Carpi 1/31/2014 6:17:00 AM
#3 Posted: 1/16/2014 4:19:01 PM
Fridel Selitsky
Fridel Selitsky
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made ​​in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
#4 Posted: 1/30/2014 4:14:59 PM
Fridel Selitsky
Fridel Selitsky
TorSphere.smz (5 KiB) downloaded 168 time(s).
Davide Carpi 1/31/2014 6:16:00 AM
#5 Posted: 11/5/2014 1:35:17 PM
Fridel Selitsky
Fridel Selitsky
Rotation around the coordinate axes
ButKlejn.smz (6 KiB) downloaded 137 time(s).
Davide Carpi 11/5/2014 2:10:00 PM
#6 Posted: 2/2/2015 11:03:15 AM
Fridel Selitsky
Fridel Selitsky
1.Torsion and bending Plate
2.Torsion and bending cylindrical panel
Using nonlinear coordinate transformations
Plate.smz (6 KiB) downloaded 160 time(s).
4 users liked this post
Andrey Ivashov 2/26/2016 9:19:00 AM, Davide Carpi 2/2/2015 8:47:00 PM, IVR 2/5/2015 3:07:00 PM, ioan92 2/26/2016 7:12:00 AM
#7 Posted: 2/26/2016 6:57:04 AM
Fridel Selitsky
Fridel Selitsky
Rotation About an Arbitrary Axis in Space
The algorithm is taken from the book. F. Rogers and J. A. Adams. Mathematical
Elements for Computer Graphics,second edition. McGraw-Hill Publishing Company,
1990,pages 121-127
Rotation2.smz (9 KiB) downloaded 126 time(s).
Davide Carpi 2/26/2016 8:25:00 AM, Andrey Ivashov 2/26/2016 9:19:00 AM, ioan92 2/26/2016 10:57:00 AM
#8 Posted: 2/28/2016 6:17:42 PM
983 likes in 6866 posts.
Rotation2.smz ,,,, does not work Smath 5346
egamma: not defined [does not evaluate]
ex, ey, ez don't evaluate ,,,
Smath 5346 does not recognise Rotatio2 coding.
Thanks for the other ones.
#9 Posted: 2/28/2016 9:30:29 PM
Fridel Selitsky
Fridel Selitsky
For SMath 5890 file works fine. For SMath 5346 file can not verify.
#10 Posted: 11/15/2016 4:29:15 PM
Fridel Selitsky
Fridel Selitsky
Building the surface deflection a Circular Plate for periodically applied load (Smath 0.98.5935)
Timoshenko.sm (389 KiB) downloaded 156 time(s).
Davide Carpi 11/15/2016 7:34:00 PM
#11 Posted: 11/16/2016 12:10:08 AM
Thanks: very nice. That's how you can tell the age of the lady !
#12 Posted: 2/23/2017 6:07:26 AM
Fridel Selitsky
Fridel Selitsky
Tension,torsion and bending beams
Beams.smz (15 KiB) downloaded 125 time(s).
Davide Carpi 2/23/2017 9:15:00 PM
#13 Posted: 4/19/2017 4:46:02 AM
Fridel Selitsky
Fridel Selitsky
Dome of Viviani Windows
The dome is made out of a variable number of Viviani curves generated by the intersection of the
hemisphere and the moving cylinder.A real-life application of this can be seen at the Osaka Maritime Museum
https://en.wikipedia.org/wiki/Osaka_Maritime_Museum
V4.sm (23 KiB) downloaded 106 time(s).
frapuano 4/19/2017 9:15:00 AM, NDTM Amarasekera 4/19/2017 12:14:00 PM, Davide Carpi 4/23/2017 7:33:00 PM
#14 Posted: 4/23/2017 6:24:49 AM
Fridel Selitsky
Fridel Selitsky
Gateshead Millennium Bridge
http://en.wikipedia.org/wiki/Gateshead_Millennium_Bridge
The arch and the bridge deck can be rotated together around large bearings, lifting the bridge deck to let small ships and boats pass underneath. This is the essential idea behind the Gateshead Millennium Bridge, a pedestrian and cyclist tilt bridge. It spans the River Tyne in England between Gateshead on the south bank and Newcastle upon Tyne on the north bank.
Most.sm (34 KiB) downloaded 104 time(s).
#15 Posted: 4/26/2017 10:00:02 AM
Fridel Selitsky
Fridel Selitsky
Continuation. The principle of operation of the bridge
Most.sm (34 KiB) downloaded 100 time(s).
NDTM Amarasekera 4/26/2017 11:37:00 AM, Arie 4/26/2017 11:13:00 AM, Davide Carpi 4/26/2017 7:14:00 PM, frapuano 4/27/2017 1:28:00 AM
#16 Posted: 6/5/2017 8:04:06 AM
Fridel Selitsky
Fridel Selitsky
Beam of rectangular section. Very simple code.
Section.sm (17 KiB) downloaded 129 time(s).
NDTM Amarasekera 6/5/2017 10:51:00 PM, Davide Carpi 10/10/2017 11:52:00 AM, Arie 6/5/2017 3:54:00 PM
#17 Posted: 6/5/2017 2:09:00 PM
Thanks Ber7,
I love those things that move, but they dilute my "winter chicken brain" !!!
You may want to roll the torus. Very nice in Mathcad, unfortunately, can't
attach the animation because XP Pro. does not support any of the Mathcad "Codecs".
Torus.sm (155 KiB) downloaded 89 time(s).
#18 Posted: 10/8/2017 4:39:32 PM
Fridel Selitsky
Fridel Selitsky
#19 Posted: 4/9/2018 3:42:55 PM
Fridel Selitsky
Fridel Selitsky
Updated
Rotation4.sm (27 KiB) downloaded 87 time(s).
Davide Carpi 4/10/2018 4:11:00 AM
#20 Posted: 6/5/2018 12:31:28 PM
Fridel Selitsky
Fridel Selitsky
The spiral curved along a given 3d curve
Spiral1.sm (21 KiB) downloaded 90 time(s).
Spiral4.sm (20 KiB) downloaded 88 time(s).
Spiral5.sm (19 KiB) downloaded 82 time(s).
Davide Carpi 5/5/2020 3:56:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
