Data Table Parsing Function - Intelligent VLOOKUP()
Data Table Parsing Function - Intelligent VLOOKUP() - Messages
#1 Posted: 1/2/2017 9:33:38 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 494 posts.
I would like to share an example of function that extracts rows from a data table based on set value in selected columns:
VLOOKUPdataparse.sm (17 KiB) downloaded 94 time(s).
Davide Carpi 1/3/2017 6:54:00 AM, francesco rapuano 12/31/2024 12:37:00 AM
#2 Posted: 1/2/2017 9:39:38 PM
Alexander O. Melnik
Alexander O. Melnik
I do need help with an interesting behaviour of a matrix definition:
If an element of a defined matrix contains a user defined function with an undefined parameter it may inthrow an error similar to here (same SMath file as above):
I would expect the function with undefined parameter to return itself instead of giving an error code.
#3 Posted: 1/3/2017 7:06:30 AM
1417 likes in 2873 posts.
Very nice
I think the issue comes out because there isn't a way to stop the preprocessing in user-defined functions when you pass an unknown (and an unknown is not a valid input).
A workaround that might be useful even to avoid the use of other functions is to use a string as input in the second row, and a check in your lookup like this:
frapuano 1/3/2017 10:44:00 AM, Alexander O. Melnik 1/3/2017 8:45:00 AM
#4 Posted: 1/3/2017 9:06:46 AM
Alexander O. Melnik
Alexander O. Melnik
Davide,
Is the a reason why function like findstr() does not return itself when not all variables are defined? Similar to this:
http://en.smath.info/forum/yaf_postsm36158_cases-in-definition-of-a-function.aspx#post36158
Also I am not sure if this is similar, but after I modified my excel_IO() function to return FALSE if undefined variables were present it would preprocess correctly with undefined variables when passed as an argument to a user defined function (you and I had an email discussion about this).
P.S.: the reason why a more general solution is desired is because a one might want to implement a more complex boolean check, than <>=!
#5 Posted: 1/3/2017 12:37:22 PM
It is by design. However even returning itself, you will have always var=findstr(...) -> false -> ... (it doesn't prevents the strcont() function to be evaluated)
Yes, but with functions created on the canvas this isn't possible
You can try with this:
strcont() is defined locally to avoid the preprocessing on the canvas
try() function is added because when you use el(...) inside the lookup function, all the elements of the condition matrix are evaluated -> you have to allow any type of input as first argument or let it fails silently (because strrep requires strings); note that if the selected element of the condition matrix is the one that contains strcon() with a wrong type as first argument, the error string will trigger an error on bool#:eval(bool#*operand#), because operand# will be a string.
Alexander O. Melnik 1/3/2017 12:41:00 PM, frapuano 1/3/2017 2:55:00 PM
#6 Posted: 1/3/2017 3:06:28 PM
983 likes in 6866 posts.
Alex,
The attached proposal is for fixed "credit".
It might be ranged via bolean.
Alex VLOOKUPdataparse.sm (33 KiB) downloaded 90 time(s).
Alexander O. Melnik 1/3/2017 3:37:00 PM
#7 Posted: 1/3/2017 3:37:30 PM
Alexander O. Melnik
Alexander O. Melnik
Alex,
Thanks, Jean. I havent used "truth tables" yet; they seem to work quite well.
#8 Posted: 1/6/2017 8:53:23 PM
Alexander O. Melnik
Alexander O. Melnik
Is there a quicker way to assemble a SMath matrix from rows than stack()?
In vb.net I can assemble 13x10000 SMath matrix in 3.3 seconds (excel_OUT), while stacking of 488 rows (13 elements each) into matrix within SMath takes 21 seconds
Thanks!
#9 Posted: 1/9/2017 7:49:47 AM
Hello Alex, can you attach an example where stack it is so slow?
#10 Posted: 1/9/2017 10:31:18 AM
Alex,
It depends what you assemble, and how.
Three examples attached.
Alex Assemble Matrix.sm (32 KiB) downloaded 73 time(s).
#11 Posted: 1/9/2017 1:52:25 PM
Alexander O. Melnik
Alexander O. Melnik
Here it is - I use EXCEL to input 10000 x 13 matrix into SMATH - 1.2 seconds. Vlookup() loop to stack 400 rows - 15 seconds. Vlookup() loop which does not stack anything is 3 seconds.
VLOOKUPslow.sm (27 KiB) downloaded 76 time(s).
DATA.xlsx (1 MiB) downloaded 82 time(s).
#12 Posted: 1/9/2017 9:06:51 PM
Try this; basically removes all stack() calls to build the matrix after you check all the conditions. On my notebook is 50% faster than your.
VLOOKUPfast.sm (31 KiB) downloaded 148 time(s).
Alexander O. Melnik 1/9/2017 9:14:00 PM
#13 Posted: 1/9/2017 9:13:40 PM
Alexander O. Melnik
Alexander O. Melnik
Much better, thanks.
Could you explain how does the following exactly work:
resultrng#:el(data#,matches,range(1,cols(data#)))
#14 Posted: 1/9/2017 9:32:49 PM
You're welcome
It is this feature; in the 2nd argument of el(3) there are all the rows I want from first argument's matrix, as 3rd argument all the columns. The result is a matrix of the elements that fits both the requirements, in the given order.
#15 Posted: 4/23/2021 12:20:54 AM
xsynt
xsynt
0 likes in 1 posts.
thank you for sharing these function, lookup is another essential features of spreadsheet and could be better if it has to be include in standard distribution.
from vlookupfast.sm modification, may it be simplified for such a situation below. in case condition only use boolean 'equal to' as the same in any spreadsheet function.
#16 Posted: 4/23/2021 3:29:41 PM
There area dozen of lookup. If so many for so many applications.
Be more specific c/w *.sm document.
#17 Posted: 4/23/2021 3:36:59 PM
... visit this intelligent/advanced lookup.
Utilities Matrix Locate Array1 Array2.sm (70 KiB) downloaded 86 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
