control Font Style of text on graphs?
control Font Style of text on graphs? - It is possible control Font Style of text displayed on graphs? - Messages
#1 Posted: 12/4/2024 9:44:46 PM
Oscar Campo
Oscar Campo
124 likes in 298 posts.
Please see the following image...
[albumimg]1722[/albumimg]
Fonts on graphs.sm (5 KiB) downloaded 55 time(s).
How to Control Font Style on Graphs in SMath?
Maybe is possible implement on x-y graph plugin?
best,
Oscar
#2 Posted: 12/4/2024 10:55:51 PM
francesco rapuano
francesco rapuano
12 likes in 38 posts.
Hi Oascar,
probably my answer is not strictly related with your question but I see that you want to create like a callout with a textual part enclosed in a rectangle.
Just for the callout part probably can be of some help this post here
Then you can add a rectangular shape and overlap to it a label text always using the XY Plot Plugin.(Hoping that the textual part is not hidden by the rectangualr one .. but if the rectangle is not filled should be feasible the thing t least from a conceptual viewpoint)
Obviuosly it is a longer process despite your one .
Take care and best regards
Franco
#3 Posted: 12/4/2024 11:29:31 PM
Oscar Campo
Oscar Campo
Hi Oascar,
Franco
Thanks Franco,
Your post about callouts on XY Plot plugin was my inspiration. The problem is that the text is independant of the zoom you apply on the graph and the lines defined by points ar totally dependant of the zoom. in this case, mix a rectangle and text will create a degenerate callout when somebody try to change the zoom on a graph:
[albumimg]1723[/albumimg]
Fonts on graphs 2.sm (17 KiB) downloaded 46 time(s).
#4 Posted: 12/4/2024 11:46:52 PM
1417 likes in 2873 posts.
You might have something related to the font family too? i.e. seems it isn't a monospaced font, that is a cornerstone in ascii drawings.
#5 Posted: 12/4/2024 11:58:56 PM
1402 likes in 1708 posts.
X-Y Plot uses 'Courier' font family for text labels.
#6 Posted: 12/5/2024 12:00:16 AM
Oscar Campo
Oscar Campo
I have tested it with a freshly installed version of SMath and it is the same.
The point is that the text (monospaced) in the native SMath graphics is displayed correctly, but not in the graph plotted by the x-y graph plugin. There is no way to control which font is used for the text in the x-y plugin through the settings. It would be really amazing if you could choose which font you would like to use.
#7 Posted: 12/5/2024 12:05:38 AM
Font in Oscar screenshot is definetly not Courier. It might be possible that the font is not installed on Oscar PC? .NET overrides the requested typeface if not found (that's the reason behind the FontFamily.GenericMonospace/FontFamily.GenericSerif etc options to initialize a font).
#8 Posted: 12/5/2024 12:07:29 AM
Oscar Campo
Oscar Campo
Please,
Can you change the font of text labels on settings and check if they really change the font inside the graph? I tried to do that but nothing happens, only can change font of axes, labels, legend, and, Title. Nothing of that affects the text inside the graph.
#9 Posted: 12/5/2024 12:21:48 AM
francesco rapuano
francesco rapuano
You are completely right Oscar , I have seen this zooming problem and differences in behaviour of shapes and text labels unlukily .
The only possibility to mitigate it is to define in a rigid way a drawing frame and ask the end user to avoid zooming ( it is probably a too restrictive approach ) .
Obviously if the usage of the documentation/program developed is for publishing or presentation purposes this issues are less important.
Other possibilities to write text labels is with a program/utilities from Razonar , If I remeber correctly they came from a Mathcad sheet conversion and don't know if the zooming issue is present in this program too.
Franco
#10 Posted: 12/5/2024 12:24:51 AM
Oscar Campo
Oscar Campo
Here is a screenshot with courier font family (I had installed):
[albumimg]1724[/albumimg]
[albumimg]1725[/albumimg]
#11 Posted: 12/5/2024 12:35:16 AM
I guessed so, since the built-in plot has a monospaced font.
What I mean is that if the Font in the plugin is initialized with a specific name (f.e. "Courier" ) and the actual font name is different (f.e. "Courier New" ) it migth not match (because are two similar but different fonts) and fall back to a standard font picked by the framework.
It is possible that you need the Courier (without new) font.
(like this - I don't have the simple "Courier" type too in Windows by default)
#12 Posted: 12/5/2024 12:40:41 AM
Please,
Something like that
It looks like the 2D Plot is using the "Courier New" font.
Davide Carpi 12/5/2024 12:41:00 AM, francesco rapuano 12/5/2024 12:47:00 AM
#13 Posted: 12/5/2024 1:12:47 AM
Oscar Campo
Oscar Campo
Something like that
I installed "Courier" font. Nothing happens... I tried on 3 different devices where I have installed SMath and I can't reproduce the same as your screenshot... (why?)
[albumimg]1726[/albumimg]
#14 Posted: 12/5/2024 1:22:28 AM
Not so fast. This is a new feature. Only I have implemented it so far.
Davide Carpi 12/5/2024 1:26:00 AM, Oscar Campo 12/5/2024 1:45:00 AM
#15 Posted: 12/5/2024 1:45:13 AM
Oscar Campo
Oscar Campo
Ok...!!!
I'm waiting for that!!
#16 Posted: 12/5/2024 1:22:29 PM
francesco rapuano
francesco rapuano
Hi Oscar,
just for completeness and information this is the post from Alvaro I was referring to ,with it there are no zooming issues because the font is vectorial , if I remeber correctly there are 2 fonts family .
Probably in this case the limiting factor is the time involved to write something on the plotting area; make me wonder if it is possible to optimize the execution time saving the vector font table avoiding that it is recalculated each time the program starts and improving the assembly of the writing label from this table , for sure Alvaro can be of better help on this topic.
Franco
Oscar Campo 12/5/2024 6:33:00 PM, Alvaro Diaz Falconi 12/5/2024 10:05:00 PM
#17 Posted: 12/5/2024 9:37:18 PM
⚜ Kenny Lemens, P.E. ᵂᴵ
74 likes in 164 posts.
Greetings,
Since we are on the subject of text, one feature I would request is the ability to plot text directly onto the graph:
I use this technique for creating dimensions on screen (and by extension, leaders). I try to limit the native 'draw text on top of graph' as graph labels (things that don't require any specific zoom to look nice, like the USC Icon in AutoCAD).
The problem is that each letter needs to be mapped; there should be a way to convert a font into plot data, but I don't know how to go about that.
May this be of Good Help;
#18 Posted: 12/5/2024 10:13:19 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi Oscar,
Franco
About speeding up the script execution, you can use that file to generate a string (for faster copy and paste) and use this function to represent it. This is because there is no NaN in SMath, otherwise it would be much easier.
Another technique could be XYPlot's new image embedding functionality. Here I copied and pasted a clipping from Oscar's example, but you could just as well generate SVG text and pass it to XYPlot.
DrawingText - JustTheText.sm (38 KiB) downloaded 60 time(s).
francesco rapuano 12/6/2024 2:22:00 AM, Oscar Campo 12/6/2024 6:41:00 AM
#19 Posted: 12/6/2024 2:26:47 AM
francesco rapuano
francesco rapuano
Sorry Alvaro but what is txtStr ?
I imagine that is a the text string to plot but how has been created and from what ? Using part of the program you developed previously to draw text in XY Plot ? and however is fast this part not as the original program at least for me .
Franco
#20 Posted: 12/6/2024 6:27:10 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
I imagine that is a the text string to plot but how has been created and from what ? Using part of the program you developed previously to draw text in XY Plot ? ...
You imagine well. It is from here:
DrawingText TXT.sm (325 KiB) downloaded 55 time(s).
... in XY Plot ?
It is not designed for XYPlot, but for native SMath Plot, although it works in both. This version is for XYPlot, which can obviously include more options.
DrawingText - JustTheText XYPlot.sm (35 KiB) downloaded 54 time(s).
... and however is fast this part not as the original program at least for me .
Maybe in your system. You can see my timings in the original post, at left of the margin. It take more than one minute for the entire worksheet in my system. BTW, like in Microsoft Word or Adobe PDF: you can choose if you want to embed the fonts in the document or not.
With this for include vectorial text in a graphic, there is no need to include the source in the document, with the fonts definitions and procedures to draw them; just a string and an auxiliary function, necessary because (I insist) SMath does not have NaN, because if it had, the function would not be necessary.
In any case, if Viacheslav includes the option to display scalable and orientable text in its plugin, this utility would almost lose all its meaning. Maybe just for some special effect.
[albumimg]1727[/albumimg]
Oscar Campo 12/6/2024 6:43:00 AM, francesco rapuano 12/6/2024 2:20:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
