rank
rank - Messages
#1 Posted: 4/19/2020 8:24:42 AM
haweHofmann
haweHofmann
3 likes in 32 posts.
Hallo zusammen,
DimEigenraum: (n-rank(A-λ*E))=1@#
should be 2
some steps of elementary row additions later
is 2
https://de.smath.com/cloud/sheet/vooDFR4FbP
any idea whats wrong?
#2 Posted: 4/19/2020 10:08:10 AM
1417 likes in 2873 posts.
This link doesn't works, be sure to use the share button link (on the right of the save button), because the address bar link is restricted to the author only.
#3 Posted: 4/19/2020 10:19:42 AM
haweHofmann
haweHofmann
Upps, sorry
Made a link
https://de.smath.com/cloud/worksheet/3BgYDE7e,
Maxima pure
(%i6) A: matrix([1,1,1,-1,0],[0,1,0,0,1],[0,0,0,1,0],[0,0,-1,2,1],[0,0,0,0,1])$
(%i7) A-1*ident(5)$
(%i5) rank(A-1*ident(5));
(%o5) 3
but
Maxima(rank(A-1*identity(5)))=4
or
#4 Posted: 4/19/2020 1:37:27 PM
1222 likes in 2150 posts.
The referenced sheet seems to use Maxima(). This doesn't work, as third party plug-ins aren't available in the cloud version.
It is better to attach such files here.
#5 Posted: 4/19/2020 1:50:54 PM
983 likes in 6866 posts.
rank(M) ... matrix rank is Smath built-in.
Here is a most precious application.
Matrix PseudoInverse.sm (111 KiB) downloaded 53 time(s).
#6 Posted: 4/19/2020 2:09:48 PM
haweHofmann
haweHofmann
and in how far do your example explain the incorrect calculation
the Maxima part calculate the single eigenvalue which is set manually in cloud version
SMath Studio 0.99.6884 - [JordanMatrix5x5-5fachEW-HV.1.2.Stufe.sm_]_2020-04-19_19-07-08.jpg
JordanMatrix5x5-5fachEW-HV.1.2.Stufe .sm (47 KiB) downloaded 53 time(s).
#7 Posted: 4/19/2020 11:51:44 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. You're right, it's a bug and there are no way to make this works (numerical nor symbolic):
First column is zero and 3th = - 4th columns, so can't be rank = 4.
#8 Posted: 4/20/2020 11:51:33 AM
Just advanced maths above the classroom.
Your example replies bug from incorrectly threaded input.
As given, your [5*5] matrix has no mathematical meaning.
Page1 rank.sm (11 KiB) downloaded 55 time(s).
sergio 4/20/2020 12:15:00 PM
#9 Posted: 4/20/2020 2:19:49 PM
... clean the bugger
What application do you have for "rank(,) ?
Don't confuse with Rank in Data Analysis.
rref [Row Reduce Echelon Function] is a damned long monkey business.
Has it been done in Smath ... Watson ?
#10 Posted: 4/20/2020 2:51:32 PM
... Rank(V)
Given a set of data values, the rank of each value is the position
at which that value appears in a sorted list of the data.
When values repeat, the rank is an average of the indices where
the value occurs after sorting.
  • New Posts New Posts
  • No New Posts No New Posts
