include
include - include() function allow you to include simple definitions from other documents. - Messages
#101 Posted: 4/15/2016 5:58:09 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Using Jean's files in the same directory, I updated to Mike's sheet and compared it to UNI's pdf ... I still have an error in the re-definition of BETA. Using latest SMath and plugins.
This is on my work computer ... not the one at home.
BTW, I tried with both files on my desktop and in the "C" drive.
#102 Posted: 4/15/2016 7:43:19 PM
983 likes in 6866 posts.
... just like this
#103 Posted: 4/15/2016 11:43:26 PM
Ruben Sidranski
Ruben Sidranski
Not that BETA ... the one to the right of "FIT" per my screenshot. Everything up to that point matches UNI's PDF. I've tried moving the "BETA" down. I think that is why I have red boxes below.
#104 Posted: 4/16/2016 12:10:09 AM
уни
уни
156 likes in 355 posts.
βNlin() redefined (βNlin() := include() = 4).
#105 Posted: 7/25/2017 10:59:19 AM
Bence
Bence
0 likes in 8 posts.
Hi!
Access to Windows Enviroment Variables would be really nice:
include("%SM_INCLUDE%\fn.sm"=10
Do you think it's possible?
Thank you
#106 Posted: 7/26/2017 2:31:54 AM
1402 likes in 1708 posts.
Yes, it is possible. Will be in new release.
Davide Carpi 7/26/2017 6:49:00 AM, Bence 7/26/2017 7:19:00 AM
#107 Posted: 7/26/2017 7:19:07 AM
Bence
Bence
0 likes in 8 posts.
Awsome! Thank you!
#108 Posted: 9/5/2017 4:52:41 AM
Updated (for SMath Studio 0.98.6437).
sergio 9/5/2017 12:13:00 PM, frapuano 9/6/2017 9:09:00 AM
#109 Posted: 11/11/2018 6:06:36 AM
Martin_B
Martin_B
21 likes in 84 posts.
Hi!
I updated to SMath Version 0.99.6884.
Include() cannot read Sheets saved with this SMath Version. The result looks like include(...)=0.
By examining the files I found the new worksheet tag. And the regions tag moved downwards.
after saving with 0.99.6884:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio Desktop" version="0.99.6884.37264"?>
<worksheet xmlns="http://smath.info/schemas/worksheet/1.0">
  <settings dpi="96">
    <shortcut>Formelsammlung</shortcut>
    <identity>
      <id>5f168c43-3307-422f-ab94-2a3c16977117</id>
      <revision>775</revision>
    </dependencies>
  </settings>
  <regions type="content">
    <region id="0" left="567" top="0" width="104" height="215" color="#000000" bgColor="#ffffff" fontSize="10">
      <math>
Maybe that's the reason?
Вячеслав Мезенцев 11/13/2018 7:42:00 AM
#110 Posted: 11/11/2018 11:43:47 AM
Ryan Freund
Ryan Freund
19 likes in 339 posts.
I'm having the same issues.
#111 Posted: 11/13/2018 7:41:52 AM
Updated (plugin version changed to 0.2.x.x). Try now.
Old worksheets must be saved in the new format.
#112 Posted: 2/22/2019 7:44:06 AM
Martin_B
Martin_B
found a little bug in include():
Strings containing only one space " " are imported as an empty string.
#113 Posted: 2/22/2019 8:40:39 AM
Updated. Try now.
Martin_B 2/22/2019 9:02:00 AM
#114 Posted: 2/22/2019 9:00:54 AM
Martin_B
Martin_B
What a quick answer!
I forgot to mention, that I use the latest stable 0.99.6884.
As the plugin is not offered through the plugins dialog, I downloaded the latest file directly and replaced the current one.
But that doesn't work:
#115 Posted: 2/22/2019 10:20:27 AM
1417 likes in 2873 posts.
The plugin was compiled for a more recent SMath Studio, that's why you can't get it through the extensions manager and why you get the error message (in short the library rely on a different interface than the one available in your version, they can't talk each other)
#116 Posted: 2/22/2019 1:21:17 PM
Martin_B
Martin_B
Updated. Try now.
Is working, with 0.99.6988
Thanks a lot.
Could you update the plugin for the latest stable, please?
Edit:
I have a more comprehensive sheet, which I include:
now (0.99.6988 with updated include extension) the result of include is shown as usual (98 elements), but they are not accessible:
At first start a few equations were present, but finally I can't get it to work.
I can't even say, if the beta Smath app or if the extension is making troubles.
The old extension 0.2.6982.28030 works correctly, apart from " ".
#117 Posted: 2/22/2019 10:14:45 PM
Updated. Added support for 0.99.6884.
Show me .log file from the plugin directory.
#118 Posted: 2/23/2019 10:56:29 AM
Martin_B
Martin_B
Here you are:
23.02.2019 14:51:58 [ERROR] Das Objekt des Typs "System.Xml.XmlWhitespace" kann nicht in Typ "System.Xml.XmlElement" umgewandelt werden.
>The object of type ... cannot be converted to ...<
#119 Posted: 2/23/2019 1:10:39 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. Related, but in SMath:
#120 Posted: 2/23/2019 9:24:05 PM
Updated. Try now.
Martin_B 2/24/2019 5:20:00 AM
  • New Posts New Posts
  • No New Posts No New Posts
