Problem with integral
Problem with integral - Messages
#1 Posted: 4/1/2019 1:53:58 PM
dzon_doe
dzon_doe
0 likes in 2 posts.
I have a problem with the integral. Please find the exemplary attached to this post. I have defined several variables and their units. In my opinion, everything is OK but SMath does not solve it when the temperature is defined as a vector T, or solve only the first integral if temperatures are defined separately (as T.1 and T.2). Can you explain to me why SMath cannot solve this integral?
int_issue.sm (8 KiB) downloaded 85 time(s).
Best regards,
dzon_doe
#2 Posted: 4/1/2019 3:32:36 PM
983 likes in 6866 posts.
Sure it integrates an integrand and more.
int_issue.sm (11 KiB) downloaded 83 time(s).
#3 Posted: 4/1/2019 4:02:09 PM
dzon_doe
dzon_doe
0 likes in 2 posts.
To be honest, your explanation is not clear for me but I noticed that you removed all units. And in my sheet, it also works. Does the units the source of the problem?
Best regards,
dzon_doe
#4 Posted: 4/1/2019 5:22:29 PM
You first wrote:
Can you explain to me why SMath cannot solve this integral ?
Now you reply: And in my sheet it also works.
Maths are unitless, so I reject carrying units,
there are very many instances not supporting units.
Units were discussed ad nauseum in Mathsoft forum,
in > 125000 exchanges: not a single work sheet in units.
#5 Posted: 4/1/2019 6:31:52 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 likes in 1676 posts.
Hi. Try this:
#6 Posted: 4/1/2019 8:22:41 PM
1230 likes in 2155 posts.
Maxima can handle integrals with units. Yet the restriction applies that the integration variable must be undefined.
int_issue_Kr_units.sm (10 KiB) downloaded 81 time(s).
#7 Posted: 4/1/2019 10:49:00 PM
Native Smath does it in much greater elegance.
int_issue [Transit Method].sm (9 KiB) downloaded 79 time(s).
#8 Posted: 4/2/2019 9:14:40 AM
Refreshed version managed from annoying units
Integral 0000000 Transit-Units.sm (23 KiB) downloaded 66 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
