1 Pages (14 items)
Offset surface creation - Messages
#1 Posted: 10/10/2021 12:20:33 PM
An initial surface is given, given by the "createmesh" function, which forms a
network with nodes.
Dyou want to create an offset surface, offset by an amount h from the initial.
The direction of displacement surface epends on the sign of h.
Sequence of calculation:
1.Restoring the normal from the nodal points of the initial surface and we get
the nodal points of the displaced surface.
2.We connect the resulting node points
The image is built on three-dimensional graphics and can be rotated with the mouse
network with nodes.
4 users liked this post
Andrey Ivashov 10/19/2021 1:48:00 PM, Oscar Campo 10/20/2021 6:42:00 PM, Davide Carpi 10/20/2021 8:27:00 AM, Alvaro Diaz Falconi 10/10/2021 8:58:00 PM
#2 Posted: 10/19/2021 11:54:16 AM
#3 Posted: 10/19/2021 1:58:45 PM
Hi,Rezorex.I put the icon with the link using the "hyperlink" insert.
Here is a link to an article from Mapleprimes
https://www.mapleprimes.com/posts/211000-Preparing-A-Parametrized-Surface-For
#4 Posted: 10/20/2021 5:22:00 AM
Hi. Thanis Ber. A slightly different version, using only parametric functions.
Offset surface creation.sm (73 KiB) downloaded 86 time(s).
Offset surface creation.pdf (917 KiB) downloaded 70 time(s).
#5 Posted: 10/20/2021 9:45:16 AM
Thanks Alvaro, I continue to learn from you.
Fridel.
Fridel.
#6 Posted: 10/20/2021 1:31:05 PM
Converting Surfaces to Solids
The solid is formed from the initial surface, the offset surface, and the
lateral surface that connects them. The lateral surface is formed by normals
reconstructed from the boundary nodal points of the initial surface.
Solid.sm (36 KiB) downloaded 78 time(s).
Solid.pdf (309 KiB) downloaded 74 time(s).
Alvaro Diaz Falconi 10/20/2021 11:56:00 PM
#7 Posted: 10/20/2021 8:43:17 PM
Thanks ► Fridel, Alvaro
I don't have the courage to convert SS 6179 ... OK.
Keep up ... Jean.
Rotate 3D TREASURY_2 Parametric Explorer.sm (33 KiB) downloaded 65 time(s).
Keep up ... Jean.
#8 Posted: 10/21/2021 4:31:50 AM
WroteConverting Surfaces to Solids
Hi Fridel. Thanks, great job. In the attached an alternate mesh. Its advantage is that it consists of a single coordinate matrix, so it can be manipulated more easily, with translations, rotations and deformations. As disadvantages, it does not look so good and there may sometimes be a wrong line, but I guess only one.
pSolid_alternate_mesh.sm (51 KiB) downloaded 60 time(s).
pSolid_alternate_mesh.pdf (391 KiB) downloaded 72 time(s).
Fridel Selitsky 10/21/2021 5:07:00 AM
#9 Posted: 10/24/2021 11:47:27 AM
Normal to the surface on Rezonar's triangular mesh
NorSurAlvaro.sm (49 KiB) downloaded 71 time(s).
NorSurAlvaro.pdf (623 KiB) downloaded 67 time(s).
Alvaro Diaz Falconi 10/24/2021 11:40:00 PM
#10 Posted: 10/24/2021 2:59:18 PM
By same token, did you manage constructing Delaunay ?
We had no chance in Mathcad. Cheers ... Jean.
#11 Posted: 10/25/2021 10:06:52 PM
Hi. The same but with a different version for the triangular mesh.
NorSurAlvaro v2.sm (77 KiB) downloaded 62 time(s).
#14 Posted: 11/11/2021 6:54:12 AM
Creating surface thickness with triangular meshes
thickness.sm (56 KiB) downloaded 80 time(s).
thickness.pdf (732 KiB) downloaded 65 time(s).
1 Pages (14 items)
New Posts
No New Posts
