Mathcad Toolbox
Mathcad Toolbox - Contains analogs of functions from Mathcad - Messages
#161 Posted: 4/18/2023 2:22:20 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Draghilev's method for the Solve Block.
DraghilevSolveBlock.sm (549 KiB) downloaded 104 time(s).
DraghilevSolveBlock.pdf (1 MiB) downloaded 94 time(s).
#162 Posted: 4/18/2023 3:26:27 AM
1402 likes in 1708 posts.
BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
I haven't done this yet because I want the user to be able to choose the type of lines. For all sides.
#163 Posted: 4/18/2023 5:07:40 AM
Unfortunately, I can't reproduce your parametric plot example.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
Links:
1. Added support for parametric plot type
Martin Kraska 4/18/2023 11:36:00 AM
#164 Posted: 4/29/2023 4:39:57 AM
Theoretically, I can get data from any component. I can try to get the text from the text region.
Alvaro Diaz Falconi 4/29/2023 8:26:00 AM
#165 Posted: 4/29/2023 8:31:27 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Theoretically, I can get data from any component. I can try to get the text from the text region....
Amazing: That's true for a lot of components! What about to catch the text in your memo editor instead SMath's text regions? Or both, I don't know.
#166 Posted: 4/29/2023 8:52:55 AM
It's funny, I haven't tried it. I want to simplify the input of text programs. This is another way to extend the functionality of the program through third-party libraries.
A lot of useful libraries have been developed now. There is no point in repeating all this. It is necessary to create flexible interfaces for their integration and interaction with each other.
Alvaro Diaz Falconi 4/29/2023 9:32:00 AM
#167 Posted: 4/29/2023 9:39:33 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
... I want to simplify the input of text programs. ...
Yep. It would be very practical to have a tool to capture text to process it. I try to use description() function, but it has the drawback that it must be called at the worksheet level and it doesn't work well within the body of a function. Like in chess, RPN, Code or XYOptions.
#168 Posted: 4/29/2023 1:00:47 PM
SMath Studio compatibility
Plugin updated.
Changes:
- MathcadBlock: added support for TextRegion.
Click to enlarge
maple-system-python-TextRegion.sm (5 KiB) downloaded 77 time(s).
Alvaro Diaz Falconi 4/30/2023 1:25:00 PM, sergio 4/30/2023 12:37:00 PM
#169 Posted: 4/30/2023 1:14:56 PM
Plugin updated.
Changes:
- MathcadBlock: added support for function definition.
Now the function definition can be written directly in the block.
Click to enlarge
maple-system-execute.sm (8 KiB) downloaded 89 time(s).
Memo Region also supported but it has not been updated for a long time, so some of its text functions do not work.
#170 Posted: 11/25/2023 8:25:40 AM
1222 likes in 2150 posts.
Is there a chance to at least partially use units here? The values with units are disabled in the sheet, this is not visible in the png-file.
7-1.sm (29 KiB) downloaded 69 time(s).
sergio 11/25/2023 7:38:00 PM
#171 Posted: 11/25/2023 1:26:55 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
This is an option for having partial and full units support.
7-1-units.sm (35 KiB) downloaded 68 time(s).
sergio 11/25/2023 7:38:00 PM, Martin Kraska 11/25/2023 7:45:00 PM
#172 Posted: 11/25/2023 7:44:24 PM
Alvaro, thanks for the hints.
By whatever reason, the unit of the independent variable is respected in rkfixed()=even though it is set to 1 locally. Whatever locally means if that happens in the last input parameter value.
7-1_units.sm (39 KiB) downloaded 61 time(s).
#173 Posted: 5/15/2024 4:41:22 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Viacheslav. It seems that there is some issue with Rkadapt and fixed that other solvers doesn't have.
dint - Rkadapt bug.sm (24 KiB) downloaded 61 time(s).
Вячеслав Мезенцев 5/17/2024 2:00:00 AM, ioan92 5/15/2024 7:12:00 PM
#174 Posted: 5/17/2024 2:13:15 AM
Indeed, this is strange, because the source code should be very similar for all solvers. I'll try to find the differences.
Alvaro Diaz Falconi 5/17/2024 1:32:00 PM
#175 Posted: 5/17/2024 1:38:02 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Using ode solvers for evaluate double integrals.
dint-RK.sm (49 KiB) downloaded 71 time(s).
dint-RK.pdf (197 KiB) downloaded 98 time(s).
sergio 5/17/2024 7:34:00 PM, ioan92 5/18/2024 2:53:00 PM
#176 Posted: 7/25/2024 12:16:01 AM
Prmtv
Prmtv
0 likes in 49 posts.
Добрый вечер. Подскажите, как скачать этот плагин? Никак не могу это сделать, появляется ошибка при скачивании. Заранее благодарю!
#177 Posted: 7/25/2024 2:16:54 AM
Он должен загрузиться автоматически при выборе из галереи дополнений, либо при открытии любого документа, использующего плагин. Возможно это временные неполадки на сервере.
#178 Posted: 7/26/2024 1:08:54 AM
Prmtv
Prmtv
В том и дело, что и скачать на сайте не получается, и при открытии установка плагина завершается ошибкой.
#179 Posted: 10/5/2024 5:49:09 AM
I select the type of bracket for different modes of operation of the block. There are problems with drawing the system sign.
#180 Posted: 10/13/2024 2:54:02 PM
I think it would be fun to add the ability to tell the component where to insert a set of expressions: as the first parameter, as the last parameter, as parameters, as parameters before specified, after specified.
Or to indicate where to place them.
  • New Posts New Posts
  • No New Posts No New Posts
