Mathcad Toolbox
Mathcad Toolbox - Contains analogs of functions from Mathcad - Messages
#141 Posted: 4/2/2023 7:55:06 AM
1222 likes in 2150 posts.
1. Очков В.Ф., Орлов К.А., Чудова Ю.В., Ивашев А.В., Тихонов А.И. IT в инженерных расчетах: SMath & Python. Лань. 2023
Thank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching.
#142 Posted: 4/2/2023 8:02:21 AM
1402 likes in 1708 posts.
Quote
This is not the book itself, but the calculations that are used there. Unfortunately, the level of knowledge of the program leaves much to be desired. I made comments to the authors.
#143 Posted: 4/2/2023 9:31:14 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
... Очков В.Ф., Орлов К.А., Чудова Ю.В., Ивашев А.В., Тихонов А.И. IT в инженерных расчетах: SMath & Python. Лань. 2023
Hi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
[albumimg]1688[/albumimg]
3body.sm (37 KiB) downloaded 58 time(s).
#144 Posted: 4/2/2023 9:34:42 AM
It is necessary to choose the conditions of the problem in such a way that the massive body intercepts the satellite.
Alvaro Diaz Falconi 4/2/2023 9:45:00 AM
#145 Posted: 4/2/2023 9:36:00 AM
Quote
So we can look forward for an inproved version. Could you please share your comments, eventually in PM...
The pdf can be found here. I downloaded all the stuff from the companion site, who knows how long we can access this.
Unfortunately, copying from the pdf to chatgpt for translation doesn't work
#146 Posted: 4/2/2023 9:39:27 AM
You can find one of the authors here. He is open to suggestions and comments.
Links:
1. Mathcad vs SMath
#147 Posted: 4/2/2023 10:20:06 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Ok.
[albumimg]1689[/albumimg]
3body.sm (37 KiB) downloaded 62 time(s).
Вячеслав Мезенцев 4/2/2023 10:22:00 AM, Mark R Harris 4/3/2023 2:32:00 AM
#148 Posted: 4/3/2023 4:19:19 AM
Hi. Ok.
A very witty, funny and clean solution.
Click to enlarge
7-13-Three-Planets 5 (Mathcad Block).sm (26 KiB) downloaded 126 time(s).
7-13-Three-Planets 5 (Mathcad Block).pdf (61 KiB) downloaded 95 time(s).
Alvaro Diaz Falconi 4/3/2023 6:57:00 AM, Mark R Harris 4/4/2023 4:19:00 PM
#149 Posted: 4/4/2023 1:59:18 AM
Little bit more.
Click to enlarge
7-13-Three-Planets 6 (Mathcad Block).sm (26 KiB) downloaded 115 time(s).
7-13-Three-Planets 6 (Mathcad Block).pdf (67 KiB) downloaded 97 time(s).
#150 Posted: 4/4/2023 7:05:04 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Utility for call dsolvers for initial and boundary values problems from a solver block.
RKA.pdf (931 KiB) downloaded 132 time(s).
RKA.sm (308 KiB) downloaded 119 time(s).
#151 Posted: 4/4/2023 8:57:48 PM
CBG
CBG
77 likes in 312 posts.
Hello
I Can't Install the Mathcad Toolbox Plugin
Click to enlarge
Carlos
#152 Posted: 4/5/2023 1:53:12 AM
Does it happen only with this plugin or with others the same? Try deleting the plugins folder completely and try installing again.
#153 Posted: 4/5/2023 2:29:16 AM
You can add your documents as add-ons and then include them with the include() function.
This function automatically searches for files in the folder with extensions. This way you can update them individually.
Alvaro Diaz Falconi 4/5/2023 11:56:00 AM
#154 Posted: 4/5/2023 4:28:42 AM
'Given' keyword also can be supported but I don't know how it will look like. Only the component has the ability to receive a set of elements on a sheet. The solution should be convenient and universal.
#155 Posted: 4/5/2023 12:01:21 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
You can add your documents as add-ons and then include them with the include() function. ... This function automatically searches for files in the folder with extensions. This way you can update them individually.
Hi. That function looks great. Is there an example of using a document as an add-on?
#156 Posted: 4/5/2023 7:54:34 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
I think that SMath do not need a Given - Find block, because it have your solve block. For example, it could be used like this
#157 Posted: 4/6/2023 10:29:56 AM
Try to log in here using the registration data in the program: https://en.smath.com/upload/extensions.aspx
You should see this picture:
Click to enlarge
Next, you need to choose the type of extension
Click to enlarge
Before uploading a file, you need to fill in the document properties. Later, you can delete the file if necessary.
Click to enlarge
If the registration data is not suitable, then you need to request them from Andrey via e-mail.
The registered files will be available through the gallery.
Click to enlarge
Alvaro Diaz Falconi 4/6/2023 12:44:00 PM, sergio 4/7/2023 12:54:00 PM
#158 Posted: 4/17/2023 6:58:15 AM
SMath Studio compatibility
Plugin updated.
Changes:
- added support for sequence operation (sys - default, mat, line);
- base frames drawing for error and eval states restored.
Click to enlarge Click to enlarge
sergio 4/17/2023 7:38:00 AM, Martin Kraska 4/17/2023 4:44:00 PM, Alvaro Diaz Falconi 4/17/2023 5:16:00 PM
#159 Posted: 4/17/2023 4:43:23 PM
Unfortunately, I can't reproduce your parametric plot example.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
Mathcad block.sm (13 KiB) downloaded 64 time(s).
#160 Posted: 4/17/2023 5:22:41 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
...How to fix this? ...
Use ~t instead t in list, but t in the range.
That's very original!
  • New Posts New Posts
  • No New Posts No New Posts
