Modeller Region
Modeller Region - Introduction of Modeller Region with how to use step-by-step instruction - Messages
#41 Posted: 11/3/2018 10:28:11 AM
Martin_B
Martin_B
21 likes in 84 posts.
Hi!
At the moment I cannot drag any object from the template pane to the modeller region.
I am using 0.99 (6839)
But you can test it easily by opening the example in the first post online. There it doesn't work, too.
Also the tooltip by hovering the any template objects appears only rarely.
Editing already exiting objects works fine.
kind regards,
Martin
#42 Posted: 11/4/2018 1:40:54 PM
983 likes in 6866 posts.
From the 5 years ago # post, it looks like Modeller was left in limbo.
6179 has no object in the template pane... just a dead cumbersome
region of no use for real projects.
#43 Posted: 11/4/2018 3:44:19 PM
Martin_B
Martin_B
Or offline:
#44 Posted: 11/4/2018 10:27:36 PM
I can reproduce Martin example [some comments added]
#45 Posted: 11/18/2018 3:53:18 PM
Dominik Skrycki
Dominik Skrycki
0 likes in 3 posts.
The "Drag and drop" function is not working.
I have downloaded an examples with modeller region and I can move/change shapes in modeller but I can't add new shapes from templates bar.
Does anybody can help ?
#46 Posted: 11/18/2018 9:11:55 PM
You can only add shapes that you have created or borrowed from unknown sources
In this document, two objects were created and installed in the template
N =5 => yellow square
N 13 => light gray dodecagon
Check if it works in your SS version
modeller-demo-Kr.sm (15 KiB) downloaded 108 time(s).
#47 Posted: 11/19/2018 3:35:00 AM
Dominik Skrycki
Dominik Skrycki
0 likes in 3 posts.
Thank you Jean for help.
I have opened your document and I see that 3 shapes (2 dodecagon and 1 square) have you added to moddeller work space from template bar.
But I can't select and add any shape from template.
As I said - drag and drop function not works.
One more thing.
I have downloaded "RainboGame.exe" and drag and drop function works fine.
But it has not work in "exe" files created by me.
#48 Posted: 11/19/2018 6:00:38 AM
1417 likes in 2873 posts.
Updated, please try now.
#49 Posted: 11/19/2018 1:18:05 PM
Dominik Skrycki
Dominik Skrycki
0 likes in 3 posts.
Thank you Davide for help.
Now I can drag and drop shapes but I can't zoom in and out shapes using mouse scroll.
#50 Posted: 11/19/2018 8:37:39 PM
You're welcome
You can only zoom the modeller canvas, not the single shapes (even in previous versions).
P.S. another update made because templates weren't detected on mouse move (no template name shown, f.e.)
#51 Posted: 11/19/2018 9:21:08 PM
SS 6179, zoom is by handles and thus fabricate otherwise than native.
1. The blue line come automatically 45° ... make it as thick as desired.
2. The arrow, you can rotate at will from the creation.
Observe the the empty "" fill arrow
3. Fill color applies to closed shapes
4. for some weird figure it can be done by digitizing and collecting the XY vector.
Modeler takes only pairwise XY vector ... not matrix
modeller-demo-Kr.sm (27 KiB) downloaded 89 time(s).
#52 Posted: 11/19/2018 10:05:03 PM
... Airfoil added Observe => [5*Airfoil,"red",2,clr]
modeller-demo-Kr.sm (39 KiB) downloaded 86 time(s).
#53 Posted: 11/19/2018 10:32:35 PM
... streamlines added around airfoil
Some cleanup needed ...
modeller-demo-Kr.sm (133 KiB) downloaded 105 time(s).
#54 Posted: 12/31/2019 4:23:50 PM
Ryan Freund
Ryan Freund
19 likes in 339 posts.
Is there anyway to have the center of the modeler canvas moved so that (0,0) is not at the center?
See attached.
Modeller - Shapes - Canvas Center.sm (11 KiB) downloaded 98 time(s).
#55 Posted: 12/31/2019 5:33:43 PM
Maybe YES ... in the attached objects are disposed/located.
modeller-demo-Kr.sm (162 KiB) downloaded 72 time(s).
#56 Posted: 1/1/2020 12:02:19 AM
AFAIK, not as you state it. Why do that ?
1. Slide the shape [circle] in the canvas.
2. Click-in to see the dotted frame [3 big black dots per side]
3. Double click to get the coordinated [X,Y]...[0,0 = centered canvas]
...width/height for circle/ellipse ...size the shape [zoom ±].
If you have some difficulties ... please don't hesitate.
#57 Posted: 1/1/2020 12:51:16 AM
... you can toy things for an all evening demo.
modeller-demo-Kr.sm (164 KiB) downloaded 76 time(s).
#58 Posted: 1/3/2020 10:04:16 AM
1222 likes in 2150 posts.
Jean, in your example you could specify an appropriate default size of the objects. Then the arrow template doesn't appear as a single dot any more.
#59 Posted: 1/3/2020 10:47:42 AM
Yes, but to make it interactive, you need slider regions. Use a function as predefined layout. It's third and fourth arguments are channels to convey the canvas co-ordinates.
The canvas is centered at these co-ordinates, evaluated for the default scale.
The default scale is given by the second entry of the dependent layout row vector.
Modeller%20-%20Shapes%20-%20Canvas%20Center_Kr.sm (13 KiB) downloaded 100 time(s).
2020-01-03 14_33_43-SMath Studio 0.99.7251 - [Modeller%20-%20Shapes%20-%20Canvas%20Center.sm_].png
frapuano 1/3/2020 3:37:00 PM, Jason McCool 4/10/2021 12:34:00 AM
#60 Posted: 1/3/2020 12:00:42 PM
Thanks Martin, most appreciated ... updated.
modeller-demo-Kr.sm (162 KiB) downloaded 122 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
