1 Pages (11 items)
min function not defined - min function not defined - Messages
#1 Posted: 9/27/2024 3:40:02 AM
#2 Posted: 9/27/2024 1:36:11 PM
Hi [userlink]nominal_diameter[/userlink],
as stated in the function description, min() returns the minimum value of a vector (or matrix), in a single argument. Same goes for max().
#3 Posted: 9/27/2024 2:03:38 PM
#4 Posted: 9/27/2024 8:43:15 PM
Thank you both for the response.
ioan92, the software won't allow me to use semicolons instead of comas, nothing happens when I push the semicolon button. How do I insert the semicolon?
Besides the semicolons, is there any difference that I'm missing?
#6 Posted: 9/27/2024 11:01:19 PM
#7 Posted: 9/27/2024 11:43:40 PM
What is the error message returned by the function?
(Hover the mouse over the region to display the popup baloon or use the lastError variabile to display as string on canvas)
#8 Posted: 9/27/2024 11:54:13 PM
Hi Davide,
On both Min and min, the baloon says function is not defined.
#9 Posted: 9/28/2024 12:14:12 AM
It Is possible that you don't have the Custom functions plugin installed.
If that's the case, inside SMath Studio:
- go to Tools > Plugins...;
- switch Local storage into Online gallery;
- search the plugin in the list;
- download it.
Alternatively if you open a worksheet that contains a function from that plugin, the program will prompt a dialog to install it.
Once installed you should be able to use those functions, unless there is some bug 🐛, in that case we will investigate it further.
- download it.
#10 Posted: 9/28/2024 12:28:58 AM
Hi nominal_diameter,
Please load the attached file from my message and tell us what happens.
nominal.sm (4 KiB) downloaded 82 time(s).
regards,
Ioan
regards,
Ioan
Do to others as you would like them to do to you!
Knowledge is of no value unless you put it into practice - Chekhov
#11 Posted: 9/28/2024 2:42:39 AM
I didn't have the custom functions installed! I'm relatively new to Smath, I just recently switched over from mathcad. Thank you all for the help!
1 Pages (11 items)
New Posts
No New Posts
