min function not defined
min function not defined - min function not defined - Messages
#1 Posted: 9/27/2024 3:40:02 AM
nominal_diameter
nominal_diameter
0 likes in 5 posts.
I'm struggling with the 'min' function. Could someone please point out where I'm going wrong? Thank you.
#2 Posted: 9/27/2024 1:36:11 PM
1417 likes in 2873 posts.
Hi [userlink]nominal_diameter[/userlink],
as stated in the function description, min() returns the minimum value of a vector (or matrix), in a single argument. Same goes for max().
#3 Posted: 9/27/2024 2:03:38 PM
ioan92
ioan92
171 likes in 102 posts.
Hi nominal_diameter,
Try this way:
#4 Posted: 9/27/2024 8:43:15 PM
nominal_diameter
nominal_diameter
0 likes in 5 posts.
Thank you both for the response.
ioan92, the software won't allow me to use semicolons instead of comas, nothing happens when I push the semicolon button. How do I insert the semicolon?
Besides the semicolons, is there any difference that I'm missing?
#5 Posted: 9/27/2024 9:49:25 PM
Gerry_Bush
Gerry_Bush
12 likes in 14 posts.
Hi nominal_diameter
It is the use of the Min function rather than the min function that is important in this case.
The semicolon or comma is just the default separator for the list of values, set in the Tools menu under Options.
ioan92 9/27/2024 10:48:00 PM
#6 Posted: 9/27/2024 11:01:19 PM
nominal_diameter
nominal_diameter
0 likes in 5 posts.
I've tried using the Min function and still get the same result. I also tried entering a string of numbers to see if that would work, but no luck yet.
#7 Posted: 9/27/2024 11:43:40 PM
What is the error message returned by the function?
(Hover the mouse over the region to display the popup baloon or use the lastError variabile to display as string on canvas)
#8 Posted: 9/27/2024 11:54:13 PM
nominal_diameter
nominal_diameter
0 likes in 5 posts.
Hi Davide,
On both Min and min, the baloon says function is not defined.
#9 Posted: 9/28/2024 12:14:12 AM
It Is possible that you don't have the Custom functions plugin installed.
If that's the case, inside SMath Studio:
- go to Tools > Plugins...;
- switch Local storage into Online gallery;
- search the plugin in the list;
- download it.
Alternatively if you open a worksheet that contains a function from that plugin, the program will prompt a dialog to install it.
Once installed you should be able to use those functions, unless there is some bug 🐛, in that case we will investigate it further.
#10 Posted: 9/28/2024 12:28:58 AM
ioan92
ioan92
Please load the attached file from my message and tell us what happens.
nominal.sm (4 KiB) downloaded 82 time(s).
regards,
Ioan
#11 Posted: 9/28/2024 2:42:39 AM
nominal_diameter
nominal_diameter
0 likes in 5 posts.
I didn't have the custom functions installed! I'm relatively new to Smath, I just recently switched over from mathcad. Thank you all for the help!
  • New Posts New Posts
  • No New Posts No New Posts
