Vector basic operations problem
Vector basic operations problem - Error occured when adressing the vector's element - Messages
#1 Posted: 2/8/2022 1:29:49 AM
Igor K
Igor K
0 likes in 5 posts.
Hi there, thanks for your attention.
I am newbie, and I guess I've made some silly mistake, somehow misusing the basic functions, but I can't figure out what exactly I made wrong, so I really appreciate your assistance.
Attempt to get the cosine of the vector results in a "Result is above max..." error. Could someone please point out what's wrong?
of_parking_tension.sm (5 KiB) downloaded 89 time(s).
Tnx a lot.
#2 Posted: 2/8/2022 2:18:04 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Use array vectorization
Vect1.sm (7 KiB) downloaded 98 time(s).
Igor K 2/8/2022 3:30:00 AM
#3 Posted: 2/8/2022 3:30:15 AM
Igor K
Igor K
0 likes in 5 posts.
Got it, solved. Thanks.
#4 Posted: 2/8/2022 7:53:53 AM
983 likes in 6866 posts.
In Smath, two of the builtin functions needs be
integrate/vectorized ... if not: "x not defined".
Welcome to Smath Community.
#5 Posted: 2/8/2022 10:28:19 AM
Igor K
Igor K
0 likes in 5 posts.
Thank you Jean for supplementary explanation, but I'm not sure I got it clearly. Do you mean that if the expression includes more than one built-in function, as in your snippet (cos,sqrt), than it should be vectorized either as in previous example in this thread, or using the loop, as in your snippet? Could you please share some sources from which I could obtain in-depth description of this concept in order to save your time?
Thank you very much. Your attitude is appreciated.
#6 Posted: 2/8/2022 10:47:36 AM
The for loop will take any length and export ... simply !
The previous vectorize is a display only. Same not same for end use.
More vector maths attached ... not updated for 6 years.
Cheers, enjoy Smath ... Jean.
VectorField StreamLines Joukowsky Airfoil.sm (38 KiB) downloaded 75 time(s).
Vector Maths Direction Cosine [Dist-in-Space] Copy.sm (83 KiB) downloaded 70 time(s).
Vector Maths.sm (1 MiB) downloaded 78 time(s).
Igor K 2/8/2022 10:50:00 AM
#7 Posted: 2/8/2022 3:42:03 PM
... doctored.
Vector Maths Direction Cosine [Dist-in-Space] Copy.sm (85 KiB) downloaded 80 time(s).
#8 Posted: 2/13/2022 11:51:54 AM
555 likes in 1333 posts.
Near all new users doesn't understand him.
Experienced users learned to ignore him.
Search his name in mathcad forums around 2010-2012.
People over there appreciated when he left there.
Because of his unfounded claims and ridiculous posts.
So he left there just continues to pollute this forum.
I look forward to that happy upcoming day of departure of him.
Oscar Campo 2/14/2022 12:43:00 PM
#9 Posted: 4/18/2022 1:11:40 AM
Igor K
Igor K
0 likes in 5 posts.
that's utterly hilarious.
#10 Posted: 4/18/2022 7:13:48 AM
Can you refresh the original demand.
I lost track of it in the blue.
#11 Posted: 4/18/2022 10:13:27 AM
There is no need for your useless posts in this topic.
First post has the question.
Use array vectorization.
Ber7 already answered it correctly.
Topic owner thanked as it was the answer.
#12 Posted: 4/18/2022 10:55:38 AM
2 more undefined 'x' complains.
1. Smath Simpson does not recognize the Power Function X^Y
2. Does not recognize Lamvert W(x)
#13 Posted: 4/18/2022 11:20:50 AM
You give gf
The for loop returns gf
In most applications you vectorize over sqrt
Some applications needs vectorize inside sqrt and over sqrt
#14 Posted: 4/18/2022 3:00:19 PM
Jean, you are necroposting.
Question is already answered.
Don't spam the forum.
https://en.scratch-wiki.info/wiki/Necropost
  • New Posts New Posts
  • No New Posts No New Posts
