Function intersection
Function intersection - Messages
#1 Posted: 2/18/2017 4:03:25 AM
mdominiak
mdominiak
0 likes in 23 posts.
Hi there,
is it possible to get exact point of functions intersection in Smath somehow? I have simply linear and constant function.
BR,
Marcin
#2 Posted: 2/18/2017 6:00:22 AM
115 likes in 329 posts.
There are more opportunities: without the use of plugins, for example, you can use the function or the method of inversion of the matrix.
[albumimg]1451[/albumimg]
mdominiak 2/18/2017 6:44:00 AM
#3 Posted: 2/18/2017 6:45:09 AM
mdominiak
mdominiak
Thanks!
What with quadratic or higher function?
BR
#4 Posted: 2/18/2017 7:18:48 AM
The method 2, of course, no; the method 1 yes, but get only one solution.
You can also use the internal function, "solve", or the plugins.
Search on the forum the plugins "nonlinearsolvers" and "maxima". Allow to extend the solution of nonlinear equations (reading the discussions can also highlight some limitations highlighted by users).
#5 Posted: 2/18/2017 12:48:24 PM
983 likes in 6866 posts.
Read the first example carefully. 'solve' is inaccurate on long range
but the initial is good enough to reduce the brackets. Wise to check
with accurate 'Dichotomy'.
Forum Solve.sm (15 KiB) downloaded 87 time(s).
#6 Posted: 2/18/2017 7:51:12 PM
"roots" is a great solving companion:
solve explicit & solve general intersection.
Solve roots.sm (12 KiB) downloaded 94 time(s).
#7 Posted: 2/20/2017 3:42:21 AM
mdominiak
mdominiak
Thanks for help.
  • New Posts New Posts
  • No New Posts No New Posts
