One more about lens
One more about lens - Messages
#1 Posted: 12/1/2024 1:52:00 AM
Valery Ochkov
Valery Ochkov
55 likes in 633 posts.
How can we use here a Mathcad-block?
Lens-Mathcad-Block.sm (43 KiB) downloaded 69 time(s).
See too
https://en.smath.com/forum/yaf_postst25212_Lens.aspx
#2 Posted: 12/1/2024 6:08:12 PM
1402 likes in 1708 posts.
Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions.
This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now.
Valery Ochkov 12/2/2024 3:44:00 PM
#3 Posted: 12/1/2024 7:52:45 PM
1222 likes in 2150 posts.
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot.
Here, an option of setting the aspect ratio of the axes to 1 would be good.
Valery Ochkov 12/2/2024 3:45:00 PM, francesco rapuano 12/3/2024 4:21:00 AM
#4 Posted: 12/7/2024 1:02:58 PM
Valery Ochkov
Valery Ochkov
Mathcad Prime
#5 Posted: 12/8/2024 1:05:34 AM
Cornel
Cornel
2 likes in 78 posts.
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
#6 Posted: 12/8/2024 1:21:21 AM
Valery Ochkov
Valery Ochkov
Not yet, but will be soon!
Question - why is the answer meters squared, and not just meters?
#7 Posted: 12/8/2024 2:29:44 AM
What's wrong with the existing solvers?
#8 Posted: 12/8/2024 3:54:39 AM
Cornel
Cornel
Because odesolve in Mathcad Prime:
1. Do not require to rewrite the differential equation of a higher order into a system of first order odes
2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver
3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq)
What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)?
#9 Posted: 12/8/2024 5:04:39 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi Cornel. For points 1 and 3, SMath can do what Mathcad can, and just a little more. Please, check the first post in this plugin. Can mathcad solve this odes?
RKA.sm (308 KiB) downloaded 119 time(s).
RKA.pdf (931 KiB) downloaded 132 time(s).
About point 2, one would have to review the documentation for the following plugins to see if they are capable, and to what extent, of doing what you are asking, and choose it for the solver in the SMath's solver block.
● [topic=17088]Intel ODE Solver Library[/topic]
● [topic=1918]DotNumerics[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=17067]lsoda[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
#10 Posted: 12/8/2024 8:58:47 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
See too
Hi. dsol can solve it with this setup:
RKA-Lens.sm (179 KiB) downloaded 54 time(s).
I also use the Martin's setup for the plot.
#11 Posted: 12/9/2024 10:44:48 AM
Valery Ochkov
Valery Ochkov
How to create this picture
https://en.wikipedia.org/wiki/Spherical_aberration
#12 Posted: 12/10/2024 4:11:05 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Valery. This is a way.
spherical aberration.sm (15 KiB) downloaded 63 time(s).
Oscar Campo 12/10/2024 9:43:00 AM, Valery Ochkov 12/10/2024 12:26:00 PM
#13 Posted: 12/10/2024 12:38:25 PM
Valery Ochkov
Valery Ochkov
Thanks!
The last step
#14 Posted: 12/10/2024 9:21:41 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. The screen. I also simplify a little the calculations.
spherical aberration.sm (26 KiB) downloaded 74 time(s).
francesco rapuano 12/10/2024 11:05:00 PM, NDTM Amarasekera 12/10/2024 11:16:00 PM, Вячеслав Мезенцев 12/10/2024 11:19:00 PM
#15 Posted: 12/10/2024 9:35:39 PM
Oscar Campo
Oscar Campo
124 likes in 298 posts.
Very elegant solution
Alvaro Diaz Falconi 12/11/2024 6:18:00 AM
#16 Posted: 12/11/2024 3:06:13 AM
Root-free version of the spherical lens
spherical aberration_Kr.sm (12 KiB) downloaded 57 time(s).
#17 Posted: 12/11/2024 6:22:06 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do.
Oscar Campo 12/11/2024 12:09:00 PM
#18 Posted: 12/12/2024 4:49:07 AM
Oscar Campo 12/12/2024 6:29:00 PM, Alvaro Diaz Falconi 12/13/2024 7:27:00 AM
  • New Posts New Posts
  • No New Posts No New Posts
