error: result is above max
error: result is above max - Messages
#1 Posted: 5/28/2021 10:21:06 AM
takeo kusumi
takeo kusumi
0 likes in 3 posts.
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (34 KiB) downloaded 54 time(s).
#2 Posted: 5/28/2021 10:39:29 AM
554 likes in 1333 posts.
hi,
I'm a beginner
error :
How can I solve it?
Change your calculation result from symbolic to numeric.
You can do it with eval() since they are all numbers.
#3 Posted: 5/28/2021 3:27:57 PM
takeo kusumi
takeo kusumi
0 likes in 3 posts.
Thank you
I understand the cause of the error
#4 Posted: 5/28/2021 6:40:26 PM
983 likes in 6866 posts.
eval() is a general rule but an absolute rule.
Many projects fail from eval(,).
SS 6179 does not complain as you constructed.
eval(,) is applied afterwards to isolate/accelerate.
#5 Posted: 5/28/2021 8:33:21 PM
Good application case to globalize within the program.
... in my SS 6179 timing drops from 2.6 s down to 1.6 s
#6 Posted: 5/28/2021 8:55:57 PM
takeo kusumi
takeo kusumi
0 likes in 3 posts.
Thank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
PPS.sm (176 KiB) downloaded 51 time(s).
PP2.sm (167 KiB) downloaded 51 time(s).
#7 Posted: 5/29/2021 10:50:48 AM
Thank you.
(PP2.sm)
(PPS.sm)
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
#8 Posted: 5/29/2021 12:11:55 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Thank you.
(PP2.sm)
(PPS.sm)
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
#9 Posted: 5/29/2021 12:33:20 PM
Razonar's is the correct solution.
Deleting my post.
Alvaro Diaz Falconi 5/29/2021 5:56:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
