1 Pages (15 items)
FEA BEAM ANALYSIS PLUGIN - Messages
#1 Posted: 9/5/2018 10:59:52 PM
Hi All,
Although I have been using SMath for a good 6 years, this will be my first question on the forum.
I would like to know, while using the FEA BEAM ANALYSIS PLUGIN, how can I edit the units displayed on the 2D plot? It is by default in Imperial units and I would like it displayed in Metric Units.
Thanks :d
Thanks :d
#2 Posted: 9/6/2018 1:09:09 AM
WroteI would like to know, while using the FEA BEAM ANALYSIS PLUGIN, how can I edit the units displayed on the 2D plot?It is by default in Imperial units and I would like it displayed in Metric Units.
Work sheet would help those using this plugin.
#3 Posted: 9/6/2018 1:11:41 AM
WroteWroteI would like to know, while using the FEA BEAM ANALYSIS PLUGIN, how can I edit the units displayed on the 2D plot?It is by default in Imperial units and I would like it displayed in Metric Units.
I have looked at the worked example provided and it is not discussed.
#4 Posted: 9/6/2018 1:49:03 AM
Hi, Gwannas. You are welcome. The FEA beam analysis that I know here, is this one:
https://smath.info/file/yz5sc
and it is in SI units.
Can you point to the file you refer to or upload it?
#5 Posted: 7/16/2019 12:28:42 PM
I have been using SMATH for the past few months and believe it is a great tool. I am new to this forum and joined this space for the exact same question as Gwannas.... how can I edit the units displayed on the 2D plot, while using the FEA BEAM ANALYSIS PLUGIN? It is by default in Imperial units and I would like it displayed in Metric Units.
Did anyone managed a solution for this?
Any help is appreciated.
Thanks
Thanks
#6 Posted: 7/16/2019 3:35:04 PM
WroteIt is by default in Imperial units and I would like it displayed in Metric Units.
1. Disretize your Imperial,
2. Convert the X's in metric,
3. Convert the Y's in metric,
4. Re-tabulate/augment/plot
... you can convert both directions globally
Cheers
#7 Posted: 7/16/2019 6:04:20 PM
#8 Posted: 7/17/2019 6:29:07 AM
Hi Jean,
Thank you so much for your reply.
I do understand your view yet when using the BEAM plugin I do not have access to the data that is generating the plot (or at least I don't know how to access it, perhaps you can shed some light on that
I will try to take some screenshots so you can see what I have on my screen.
#9 Posted: 7/17/2019 6:32:38 AM
File not found.File not found.File not found.
#10 Posted: 7/17/2019 8:48:48 AM
WroteI do understand your view yet when using the BEAM plugin I do not have access to the data that is generating the plot (or at least I don't know how to access it, perhaps you can shed some light on that
The all thing is a plugin, most probably can't do anything
unless designed to enter inputs in metric. Only the Creator
has an answer ... something like CoolProp.
On the other hand, your local regulations will reject as
not proven/certified. So, just classroom stuff.
I had the best sleep of my life in Norfolk [old mansion among ships]
Cheers.
#11 Posted: 7/17/2019 9:56:54 AM
Thanks for the reply.
This is such a shame as it is very limiting to show the plots.
I can input with different units, that is not a problem, its the plotting(shear, moment, deflection) that only comes up in the imperial unit....
Is there anyone with access to the code?
Norfolk is a beauty indeed
Thanks once again
Thanks once again
#12 Posted: 7/17/2019 12:46:00 PM
I don't see any public code for that plugin, so there isn't much to do on that side. However if really needed you might write some sort of "wrap function" to post-process the results and convert them to SI units.
#13 Posted: 7/19/2019 5:15:57 AM
Hi Davide,
Thanks for letting me know.
Any thoughts on where should I start with that "wrap function?
Have a good weekend.
Thanks,
Thanks,
#14 Posted: 7/19/2019 7:27:42 AM
Either
or
PlotShearDiagramSI.sm (5 KiB) downloaded 149 time(s).
![2019-07-19 12_23_05-SMath Studio - [Beam Analysis Sample-1.sm_].png](/en-US/file/mCabpN/2019-07-19-12_23_05-SMath-Studio---_Beam-Analysis-Sample-1_sm___png)
- Scale the input values
- Process FEA results using the plugin
- Fix the labels
or
- Scale the output values
- Fix the labels
#15 Posted: 8/10/2019 8:44:11 AM
1 Pages (15 items)
New Posts
No New Posts
