How to use the solve function in this task
How to use the solve function in this task - Messages
#1 Posted: 6/2/2024 8:33:38 PM
Valery Ochkov
Valery Ochkov
55 likes in 633 posts.
3-2-CoolProp-Solve.sm (46 KiB) downloaded 64 time(s).
#2 Posted: 6/2/2024 10:24:24 PM
ioan92
ioan92
171 likes in 102 posts.
Take care :
Your CoolProp function, as you write it, does not change the sign, between the two limits of the variable p :
Valery Ochkov 6/2/2024 11:27:00 PM
#3 Posted: 6/2/2024 11:27:35 PM
Valery Ochkov
Valery Ochkov
Thanks,
send please the sm-file with the solution
#4 Posted: 6/3/2024 12:42:55 AM
ioan92
ioan92
The problem, as you formulated, seems as not having a solution in real numbers, in order to be solved with the solve routine.
I'm sorry but I have no time to reformulate your problem.
If you intend to solve it numerically, try to check the continuity of the function and the fact that in the range you look for solution there is at least one change of the function value sign.
Valery Ochkov 6/3/2024 12:59:00 AM
#5 Posted: 6/3/2024 1:46:02 AM
1222 likes in 2150 posts.
The problem as stated in the opening post, actually has a solution in the given range.
Yet, I don't see an alternative to using brute force to tame the coolprop function: sampling and interpolation.
Valery Ochkov 6/3/2024 1:50:00 AM
#6 Posted: 6/3/2024 2:12:41 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. The guess values, in this case the range, are part of the solution, this means that you must know where the numerical procedure works fine. In this case the interval 1 MPa ... 6 MPa.
3-2-CoolProp-Solve.sm (49 KiB) downloaded 64 time(s).
#7 Posted: 6/3/2024 10:47:51 AM
Valery Ochkov
Valery Ochkov
Thanks, Martin and Alvaro
See please the problem in attach
Fireless-Locomotive.sm (882 KiB) downloaded 55 time(s).
PS
Alvaro!
And what about the book?
#8 Posted: 6/3/2024 12:58:22 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Valery. This could be an option.
Fireless-Locomotive.sm (915 KiB) downloaded 61 time(s).
PS
Alvaro!
I'm pretty busy right now! Sorry.
Valery Ochkov 6/3/2024 4:04:00 PM
#9 Posted: 6/3/2024 4:29:42 PM
Valery Ochkov
Valery Ochkov
It works! By p.0=240 atm
Fireless-Locomotive.sm (882 KiB) downloaded 61 time(s).
But by p.0=140 atm ---???
Alvaro>
Check please 1-2-3 chapters.
My student from Cuba is waiting for it!
#10 Posted: 6/5/2024 9:16:15 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
... Check please 1-2-3 chapters.
Hi Valery. I find it quite inappropriate that what is a voluntary collaboration helping on regarding a translation, and therefore supposedly free of commitment on both sides, is publicly claimed in the forum. This situation seems to reflect some type of irresponsibility on my part as I am failing to make some type of commitment, which, I insist, there is none. I would sincerely like to receive some kind of explanation as to why you are making a public complaint about a translation job on my part when there is no agreed commitment.
#11 Posted: 6/5/2024 11:25:56 PM
Valery Ochkov
Valery Ochkov
Please forgive me, of course I'm wrong.
Val
#12 Posted: 6/6/2024 12:18:58 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Of course. He is already forgotten.
  • New Posts New Posts
  • No New Posts No New Posts
